Diagnostics Tool Help
Looking for a little guidance on a diagnostics tool setup. From my research on here I have determined that the best setup for my vehicle is as follows
VCM or Mongoose and IDS V130
From what I can tell both the VCM and Mongoose are discontinued. Can someone please confirm this assertion?
If not can someone recommend a supplier?
I am also looking for some guidance on where to find the files needed for IDS v130
UnoJag, it does appear that the main line of cables is gone, but there are a few knock offs that may be worth a try. Here is one I found on ebay.
For Land Rover/Jaguar JLR SDD PRO V160 Cable Car USB OBD-2 Scanner Code Reader | eBay
As for the files, hopefully a member around here can help you out. I know the cable comes with V163 which would work on your car. The question then becomes what you need to do to ensure Version 163 works like you need. I find that is the harder thing to deal with and overcome.
Darrol2004
Jul 10, 2023 05:53 AM
