engine oil
Old Jun 19, 2014 | 07:00 AM
colin124's Avatar
Default engine oil
hi,going to do an oil service on my jaguar xj6 x300 1996 can anyone advise me on the correct oil,its done 123ooo miles,been told 5/30, and also 10/40 ???
Old Jun 19, 2014 | 08:35 AM
I use 10W/40, always have in that car.
I find the engine quite sweet on that brew.
Others use different viscosity.
Old Jun 19, 2014 | 08:36 AM
Doug's Avatar
I use 10/40 as well
Old Jun 19, 2014 | 09:16 AM
daxter1987's Avatar
Here is a quick guide I made:
jaghelp.com: XJ6 Fluids and Filters reference guide
Old Jun 19, 2014 | 02:21 PM
colin124's Avatar
thanks guys,10/40 it is
Old Jun 19, 2014 | 09:16 PM
aholbro1's Avatar
5/40 Rotella T6 Syn here, after trying 10/30 and 20/50.
Old Jun 20, 2014 | 03:47 AM
Fraser Mitchell's Avatar
The Owner Handbook normally tells you what oil grade to use, but for a car of that era, and in the absence of the book, I would agree with Doug, use 10W/40. There is also a 15W/40 too, that you could use, especially with those miles.
Old Jun 20, 2014 | 02:24 PM
panagiotis's Avatar
Try, or check-ask for Lubrication Engineers oils-lubricants.
You will be surprised, if try them, on their products.
This is not an advertisement, I use them all around, cars, motorbike, factory.
7 years in a car, 12 years in the motorcycle, the same oil just filter change and fill up.
In the factory I work, 600HP centrifugal compressors running round the clock, 1081 rps, yes revolutions per second, not rpm, the impellers shafts (plain bearings), 9 years the same oil, the viscosity is up to you.
kelliott
May 31, 2022 05:26 PM
ZJag
26
Sep 5, 2016 03:33 PM
bdboyle
Sep 4, 2015 06:16 AM
pnwrs2000
Sep 3, 2015 11:55 AM
OkieTim
Sep 2, 2015 12:48 PM
