failsafe engine mode
Old Oct 10, 2008 | 02:44 PM
rpeppers's Avatar
Default failsafe engine mode
What does the failsafe engine mode mean? It comes on every so often but not every day.
Old Oct 10, 2008 | 04:53 PM
hlgeorge's Avatar
Default RE: failsafe engine mode
You need to read the OBD2 codes.
Old Oct 12, 2008 | 05:18 PM
remosusa's Avatar
Failsafe (also call limp home mode), triggers when you have a fault code. If you are handy with minor tools go ahead and get you an ODB code scanner, if you own a Jag you'll eventually need one, first trouble light is the cheapest time to bite the bullet and buy you a decent code reader... most good ones can also clear the codes for you with the press of a button. Write the codes down, you'll be asked for them by most of the forum techs and other posters... help starts by knowing what your faul codes are.. If you are pressed for time, some parts stores will read them for you, BTW, ignore the P1000.
Forcedair1
Sep 8, 2025 01:57 PM
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
scottatl
Sep 4, 2015 08:08 PM
OkieTim
Sep 2, 2015 12:48 PM
