Genrad GDS3500 WDS Docking Station
Has anyone used the Misfire Monitor feature in WDS ? In my WDS it does open another tab with buttons and says to klick the tick when engine is running. But then nothing. I can press tick as many times I like but feature does not start. No error messages, no nothing. I can switch to another tab and the misfire monitor tab stays there in crashed/waiting state.
WDS has v43 software. Car where tested is my 2000 xjr.
Yes, instructions are not even 12 years old and they may help me as dock power died when something exploded inside of WDS (sparks and lot of smoke came from PCICIA opening).
[img alt="IBM 92P1014 for 16v
And
DELTA ELECTRONICS Inc DPS-250AB-22 D for mains"]https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x2000/img20241230182555_46f365fb3784899f820a89520faef9e5 2d7f943c.jpg[/img]
IBM 92P1014 for 16v And DELTA ELECTRONICS Inc DPS-250AB-22 D for mains
And
I don't know about developer mode. But it is possible to get to Engineering Mode to add value of ODOmeter, and to brick your car easy with VID Block Editor and mangle "channel" value tools.
If RESET ADAPTATIONS is an option, then it will be with an early version of WDS or later version of PDU.
As an example, when WDS was first issued it had a NETWORK INTEGRITY TEST but was later discontinued. I have many early versions of WDS but I have not loaded a PTU with anything other than 43 in years.
You might try to locate a version 10 or 21 or 30 or something like that to see if it is an available option?
bob
bob
WDS43 Screenshot for XJ-S (VIN 222840) - Setup and Configuration - available options.
