Genrad GDS3500 WDS Docking Station
Old Jun 23, 2017 | 06:07 AM
  #421
Cambo's Avatar
If anyone needs a B-203 cable one just popped up on eBay. https://www.ebay.com.au/itm/263051243575
Actually a heap of WDS cables have recently been listed, battery cables and so on.
This is just for your info, not my sale!
Old Jul 5, 2017 | 11:47 AM
  #422
Vee's Avatar
Vee
Apparently the Autologic devices, although pricey, can indeed reset throttle adaptations. You must use the x300 selection.
Im going to use an x300 VIN and see if my WDS won't offer up that option as well. It does not offer it under the XJS VIN number.
I thought it would be of interest to the thread to confirm there is another device out there that can perform this required adjustment!
Old Jul 5, 2017 | 01:24 PM
  #423
motorcarman's Avatar
Top Answer: 3
I remember XJRguy had some advise for using WDS/IDS for the late XJ-S cars.
It was a few years ago but there was a 'workaround' for that issue.
bob
Old Jul 7, 2017 | 01:43 AM
  #424
ultra rare's Avatar
Hello,
For doing a TPS Set up on any XJS 95/96 just enter a vin like 222xxx (i always use 222840, its one of my later coupes)
then TPS setup is available and WDS does it in 5 Seconds
This works with any AJ16 Engine XJS
Old Jul 7, 2017 | 09:37 AM
  #425
Vee's Avatar
Vee
TPS and O2 orientation is not a problem.
It's always been the Adaptations Reset.
Old Jul 7, 2017 | 08:13 PM
  #426
Cambo's Avatar
This is what you get in IDS V118 for a 94-96 XJS, this was a test with VIN 223xxx
WDS would be the same...
Old Jul 7, 2017 | 09:07 PM
  #427
Top Answer: 3
If RESET ADAPTATIONS is an option, then it will be with an early version of WDS or later version of PDU.
As an example, when WDS was first issued it had a NETWORK INTEGRITY TEST but was later discontinued. I have many early versions of WDS but I have not loaded a PTU with anything other than 43 in years.
You might try to locate a version 10 or 21 or 30 or something like that to see if it is an available option?
bob
Old Jul 9, 2017 | 06:13 AM
  #428
Vee's Avatar
Vee
Has anyone here done anything with fuel Trim setup option?
I believe I may have gone down that route once and it asked me for some emissions data...data that I was not capable of providing.
Old Aug 1, 2017 | 09:49 AM
  #429
Vee's Avatar
Vee
https://baltimore.craigslist.org/tls...208550335.html
For anyone looking for a WDS, this one might check all your boxes! I have no affiliation with the seller, I simply stumbled upon this ad.
Old Aug 1, 2017 | 10:55 AM
  #430
Top Answer: 3
Good Find!!!!!
Too bad it's 1500 miles away from me.
bob
Old Aug 10, 2017 | 06:55 AM
  #431
MiroGer's Avatar
Exclamation Software WDS Genrad 3500
Hello,
I would like to ask if somebody can help me to get Software WDS Genrad 3500 for Aston Martin, CD 02 and CD 13 ASAP. If its possible, please dont hesistate to contact me,
Thank you very much
MG
Old Aug 11, 2017 | 06:05 PM
  #432
y.roos's Avatar
I did sent you a PM. I can / will help you. BW.
Old Aug 26, 2017 | 01:20 PM
  #433
Vee's Avatar
Vee
I'm having trouble disconnecting the PTU from the docking station. Batteries seem to be fine. They charge up and have been configured, or whatever the term the WDS uses to discharge and recharge the battery pack.
I go through the menu commands and when I hit the check tick, I disconnect and off the screen goes.
Any suggestions? Thanks
Old Aug 26, 2017 | 06:55 PM
  #434
Top Answer: 3
You might try to boot the PTU disconnected from the docking station to see if the battery pack is capable of a full charge and load for the thing to function.
I can usually get 5 or 10 minutes on battery power but I usually leave it docked OR plug the OBDII cable into the car to get power that way. You can also connect the A204 battery power cable but the PTU should run at least a few minutes on it's own.
bob
Old Aug 27, 2017 | 08:01 AM
  #435
Vee's Avatar
Vee
I did get it to run on its own at least one time. Drained the batteries eventually and placed it back into the dock. Recharged and recalibrate batteries but never have I been able to do it again....
Old Aug 27, 2017 | 10:05 AM
  #436
Top Answer: 3
Sounds like the battery pack is faulty. It could just be low capacity (worn-out cells) or one faulty cell in the pack.
bob
Old Sep 11, 2017 | 05:46 PM
  #437
bonanza's Avatar
Hello,
I would like to thank everyone who has contributed to this thread!!! It’s a wealth of information.
I just purchased a Jaguar WDS system but I haven’t received it yet, but from the photos it boots to WIN98 screen then it wants to so a scandisk so I am not to worried about getting it up and running.
My new purchase doesn’t come with any CD’s and I would like to get some things organized before I receive it, I would much appreciate it if somebody can provide me with copies of Ghost, and the latest Jaguar software.
I have ordered the following items to upgrade my unit, all comments are appreciated:
8 - FDK HR 4/3AU Battery NiMH 1,2V 4000mAh bulk ON1342 US
128MB STICK SODIMM SD NON-ECC PC66 PC-66 66MHz 66 MHz SDRam 128 128M Ram Memory | eBay
Syba IDE 44-pin to Compact Flash Adapter Dual Slot 44 pin 2.5" Interface | eBay
Regards,
Old Sep 11, 2017 | 08:45 PM
  #438
Top Answer: 3
I have been using the the 44 pin adapter since the old HDDs are getting hard to find.. I use 4GB or 8GB.
SOME 128 PC66 will work in the memory slot. I have a few that are not compatible but claim they are. I suspect they are PC100 but they are NOT backward compatible!!!!!!!!
I use the single CF card adapters but I do have one MASTER/SLAVE card adapter and it works with two CF cards. The other card can be used as storage for Electrical Guides, JEPC and JTIS, etc. I have an old parallel printer connected for documentation HARD COPIES.
You can send me a Private Message for a way to get the 3 CDs worth of software.
Many of us have the old software available for download.
You need to copy the files to CDs and run in the docking station CD drive in succession.
It should take about 4 hours to load the software onto the WDS.
bob
Old Sep 11, 2017 | 09:19 PM
  #439
bonanza's Avatar
P.M. sent.
Thx for your help
Old Sep 11, 2017 | 09:41 PM
  #440
bonanza's Avatar
Thanks for the download "motorcarman".
