Harmonic Balancer / Vibration Dampener Seal
Old Oct 13, 2023 | 03:43 PM
OldSkoolJohnny's Avatar
Default Harmonic Balancer / Vibration Dampener Seal
Hello All, I have a quick question regarding the dampener O-Ring seal on the inside. I just completed the timing chain replacement (new chains, exhaust sprockets, guides and tensioners) utilizing the kit from Christopher's. Kudos to him for putting together a superb kit by the way. The one thing not included in his kit, and I understand why, was this seal inside the dampener where it slides onto the crankshaft. Does anyone have the part number for this and/or know where to get one? Not all the cars have this seal, I was one of the lucky ones. The repair guide says to replace it prior to installing, but doesn't give a part number for it. Including a picture for reference. Thanks for any help.
Old Oct 13, 2023 | 04:40 PM
motorcarman's Avatar
I keep a few in stock. Hope they don't become NLA.
Part number XR81139
Old Oct 13, 2023 | 06:06 PM
Part number XR81139
Thank you so much, that's just what I needed.
When I put the number in at Jaguar sites (dealerships) it says that it doesn't fit?
Drawings all show it.....Is there a different numbers for XKR vs XK8?
Old Oct 15, 2023 | 03:54 PM
All AJV8 crank dampers use the same seal as far as I know. (4.0 and 4.2)
The SC dampers are just a double belt unit but fit the same.
iTh3 Riddler
Nov 8, 2022 05:58 PM
lwz3
Jan 22, 2020 01:28 PM
OUScooby
Apr 19, 2019 11:02 PM
o1xjr
Mar 30, 2014 05:15 AM
