MAF cleaning
Old Mar 14, 2009 | 01:48 PM
MBxjr01's Avatar
Default MAF cleaning
hey guys i wanna clean my maf however what do i do just spray it in there? lol im new to this so idk what to do
Old Mar 14, 2009 | 02:01 PM
harleyrk01's Avatar
Not sure what to use yet....but I did read in alldatadiy....that they said not to use brake cleaner....because the maf was coated with something from the factory....and that this would remove that coating.....
Old Mar 14, 2009 | 10:43 PM
hlgeorge's Avatar
Use a cleaner made specifically for cleaning the MAF. Available at auto parts stores.
Old Mar 15, 2009 | 08:14 AM
Thermo's Avatar
Veteran: Navy
MB, you want to let the cleaning fluid run over the wires inside the MAF, but you don't want to spray them directly. They are fairly fine and directly spraying them has a chance of breaking the wires. They do make special MAF cleaners that come in a spray can, but you can get away with carb cleaner if you don't have any MAF cleaner.
Just make sure that you get all the fluid away from the wires prior to starting. If you don't, it can cause the MAF to sense the wrong air flow and lead to other issues.
Old Mar 15, 2009 | 08:19 AM
MBxjr01's Avatar
i have maf cleaner but when i took the sensor off it was just like a tube with 4 things connecting to a hole in the middle? do i spray it in the hole? lol idk what to do. i thought the maf sensor was right before the air filter. Name:  P1300003.jpg
i found this picture on the forum this guy is selling. on the other side theres an opening is that where i spray it in?
Old Mar 15, 2009 | 09:05 PM
Thermo's Avatar
Veteran: Navy
MB, yes, you want to spray into the hole in the center of the sensor. Just make sure to bounce the spray off of the wall of the hole.
Old Mar 16, 2009 | 12:52 AM
carguy101's Avatar
Talking
haha that is my MAF. I would sell it to you at a good price, it was the cheapest one on eBay. And IIRC that is the backside of the MAF, you would spray the other side i.e. the induction side.
Old Mar 16, 2009 | 12:59 AM
JagtechOhio's Avatar
Small world, ain't it? I was looking on eBay last night, and found an add for a sunroof assembly. The guy lifted the picture from my webpage to peddle his goods with.
Old Mar 16, 2009 | 02:15 AM
carguy101's Avatar
haha yeah my friend had found his car listed somewhere and it wasn't even for sale and scammers suck.
It's ok I also have it listed on this forum too. lol
https://www.jaguarforums.com/forum/s...ad.php?t=11573
Old Mar 16, 2009 | 01:29 PM
MBxjr01's Avatar
thanks carguy for the picture! haha just so i dont mess anything up. all i do is take off the sensor spray the crc maf cleaner into the hole only on the sides not directlly down. About how long should i let it dry before re installing? and about how much crc should i spray in? i had a xj-6 before the xjr and it seemed stuff was always breaking so im just being cautious. Ive had pretty good luck with xjr so far!
bdboyle
Sep 16, 2019 05:58 PM
shootingbrake
Sep 23, 2015 10:54 AM
Papelione
Sep 21, 2015 06:13 PM
GGabriel
Sep 18, 2015 08:44 PM
jaaag
Sep 11, 2015 12:53 AM
