More On Vibrations
Old May 24, 2022 | 09:47 AM
Beauxmont's Avatar
Default More On Vibrations
Very noticeable vibrations when idling in Drive. Not so much when in park or neutral. Also not as much when A/C is turned off. New water pump and new manifold parts. Would appreciate input.
Old May 24, 2022 | 09:48 AM
Beauxmont's Avatar
Forgot to add that it is a 2013 XF with 63,000 miles.
Old May 25, 2022 | 02:42 AM
Welcome to the forums Beauxmont,
119 Views as I write but no one had a go at a Reply. You are more likely to get advice from members with the same model by posting technical questions in the X250 forum.
Assuming the engine has a smooth and regular idle, vibration could be caused by a loose or failing engine mount (2) or transmission mount (1). Another possibility is any pulley driven engine ancilliary with a worn bearing or the same in the idler pulley or drive belt tensioner.
CzechFrank
XF (X260)
Mar 27, 2018 10:35 AM
CzechFrank
Feb 22, 2018 05:47 AM
Radogabo
Aug 2, 2017 11:07 AM
Traveller
May 12, 2017 10:09 PM
nsl1
May 9, 2014 11:15 PM
