New SDD crack.
Old May 15, 2015 | 03:05 AM
Anglofil's Avatar
How new car - MY?
Old May 15, 2015 | 08:56 AM
Albert J's Avatar
Originally Posted by Anglofil
Hi AJ!
This is probably not the right thread for fixing V139, but if we do not hear from ML it should not be that difficult to get your V139 to do programming. I have only used it on land Rovers, but I guess it is more or less the same with Jaguars. What kind of programming do you want to do? Updating ECU's, calibrating injectors, programming keys? We can go through the installation later if it is neccesary? Cheers!
My interest is to be completely functional, to be able to do both brands incl. calibration files. Not a must to have engineering.
Keys are nice on occasions as well. [I'm am working with the usual Chinese crack.]
One of my pet-peas since V130 is that IDS Legacy tries to open and then closes, and the clock spins for a short while, then the program doesn't proceed. I'm thinking there is minor seting/djustment is necessary to get it to open. [have V130 drive up and running just because of that, but how nice would it be to master it in one program, wright.?
Have Java 6-26, and Firewal disabled.
Thanks AJ
Old May 15, 2015 | 11:35 AM
Albert J's Avatar
How new car - MY?
2004 XJ8 Red.
Old May 19, 2015 | 02:17 PM
vilali's Avatar
Originally Posted by MoscowLeaper
Ok, it was a long and cold Russian winter.
I wasn't able to test a tunes for a Jaguars and i've decided to take a closer look on SDD.
The results are:
-New SDD crack. works with any SDD version (up to 141). Actually it's not a crack anymore (no exe files used, app.war remains original, e.t.c), it's a certificate, which is valid for a 6 month, with a FULL SDD subscription. No topix login/password needed, but all functions works flawlessly (updates, keys programming, engineering mode)
Two options are available - one is infinite for selected version of SDD, another one is a 6 month cert. In first case all you need is to run a .cmd file, in second case - you need to run a javascrpit file (you can view it, it is harmful), it will get you machine ID, when i'll recive it i'll be able to issue a certificate.
-Password generator for an engineering mode. Including following options:
Jaguar - VIN BYPASS, VID EDITOR,ODO APP,CCF EDIT,ODO APP1,SWDL,ODO APP2,RECOVER KEYS
LandRover - CCF_EDITOR,L316_ODO_APP,TAIWAN_VEHICLE_UPDATE,SOFT WARE_DOWNLOAD,L322_ODO_APP,L322_RECOVER_KEYS,L322_ ERASE_KEYS,
OPTION_8
These passwords can be used one time only. You give me a VIN and SEED, i give you a password
-exml decoding. Now i'm able to decode any exml file to xml and vice versa. xml can be edited (this gives a lot of options for, i.e. editing a CCF of newer cars or modifing a IVS archive to be able to flash any tune into any module)
-.vbf files CRC correction
-VID block editing. Now i've documented a contents of a VID block. Gear ratios (including rear end ratio), regional settings (i.e. to disable a CEL in case of a wrong readings of the secondary HO2S) and many more.
For a first 3 persons - it is for free
And i'd like to hear if there's any decent price for all of the above options (i mean if i can sell it )
Again, it's not commercial topic. At least for a while.
P.S. Back to the tuning, some news are coming as soon as i'll finish a tests of X351 XJR-S and 380hp XF AWD.
it is good to know, when through with the work let us know
Old May 29, 2015 | 10:16 AM
alessandro64's Avatar
Hello I am very interested in the function of decoding exml can you tell me something more? Thanks
Old Jun 26, 2015 | 04:18 PM
twisted's Avatar
Hello, are you still able to provide access to the new sdd versions, thanks.
Old Jul 9, 2015 | 06:09 AM
olabodejegede's Avatar
Originally Posted by RegGraham
I found that the crack from v135 still works OK the current version being v141 cracked OK.
However if all you want to do is modify the ccf file you don't need a the engineering password. Having installed SDD in the Runtime directory of SDD there is an html file named SoftwareDownload once you have been able to connect to the car with whatever interface you use you can exit the SDD browser session and just double click on the softwareDownload.html file. Set it into engineering mode and you can then do most or all of what you want to any JLR.
I will try and set up a little screen capture session and post it so people can see how to do it..
Pls can you provide some pictorials. What can one do with the Engineering mode,Key Programming? I have a coded access if i want to,what can i achieve with the coded access? Regards
Old Jul 9, 2015 | 02:53 PM
  #28
Originally Posted by olabodejegede
Pls can you provide some pictorials. ........
Welcome to the forum olabodejegede,
Old Jul 11, 2015 | 02:47 PM
Albert J's Avatar
Default EXE File to generate the Hardware IDs what "MoscowLaper" needs
[QUOTE=MoscowLeaper;1186732]Ok,
Hello Fellow SDD Enthusiasts,
I was thinking and expecting that the master, "Moscowleaper" would include a tool like this to have the Hardware ID reading made easy.
I had a contact write this for me, and it certainly looks like it is doing the job, Ya'll try it, and let me know.
With the result of this tool "Moscowleaper" can enable your SDD 142 installation to work. I have not done it for myself yet, but working on it.
Just extract HDWR_ID reader, and anywhere on C:\ Drive, double click it, it will generate a text file with the 3 lines of hardware identifier what You can send off to "Moscowleaper" for HIS answer code and possible instruction how to proceed and get SDD up and running.
That information exchange may even be possible here on this board, but that would be up to HIS discretion.
For instance the HDWR_ID of this machine I'm using now, looks like this,
1ZD4N73F1SZ
LVA3830
BFE9FBFF000006EC
Click on the link below, and download it from DropBox -->
https://www.dropbox.com/s/80vine0hfu...Maker.zip?dl=0
Maybe this will help .......AJ
Old Jul 16, 2015 | 02:07 AM
  #30
EJ Lewis's Avatar
SDD V142 free Index of /265935/idscentral
verified working on win 7
guide
Old Jul 27, 2015 | 01:56 PM
  #31
LoopbackZero's Avatar
Does anyone have a torrent available for the latest version? The only torrent I could find is for v138.02 ...
Old Jul 28, 2015 | 03:45 AM
  #32
RegGraham's Avatar
You don't need a torrent just download it from Index of /265935/idscentral
Old Jul 29, 2015 | 03:02 PM
  #33
SDD_142.03.exe is 1.6 GB, and SDD_142.04.exe is 751 MB -- any notable differences?
Old Jul 30, 2015 | 02:14 AM
  #34
JagV8's Avatar
Follow the readme. You install each update in order.
Old Aug 28, 2015 | 02:23 AM
  #35
paulevo's Avatar
Default New SDD crack, exml decode, VID block editing, engineering mode password
Hello Moscowleaper,
Very impressive work you did during the winter . I would like to do a test and can you make a temporarily certificate for me. If it will work for 30 days or so I would be very happy. I used your script for getting the machineID and the results are here:
L0 59SC
DSDJ012107
BFEBFBFF00040651
Thank you!
Paul
Old Sep 15, 2015 | 05:41 PM
  #36
tomfurie's Avatar
Where can I download the SPA_142 file?
It is not on Index of /265935/idscentral
philwarner
44
Nov 5, 2024 06:29 PM
JaguarLover101
48
Jun 12, 2023 10:28 AM
trosty
26
Dec 18, 2022 06:40 PM
mhamilton
US Lower Atlantic
Sep 4, 2015 05:00 PM
