Nikasil still are threat?
Old Oct 10, 2018 | 11:37 AM
Neven's Avatar
Default Nikasil still are threat?
I intend to buy XJ8 3.2 V8 MY 1999 VIN SAJJJALG3CH873743. It has about 100.000 miles, but I do not know if the engine was replaced before. Could it still be affected by the risk of problematic, original Nikasil coated engine problem?
Old Oct 10, 2018 | 11:43 AM
JagV8's Avatar
Yes - but only if you have fuel with high sulphur (aka sulfur) content.
I know fuel here does not. I do not know about your fuel.
Old Oct 10, 2018 | 11:50 AM
Neven's Avatar
Thank you for the fast reply. The car was imported from UK last year, while the fuel we have here is quite good.
Old Oct 10, 2018 | 03:02 PM
Welcome to the forum Neven,
If a nikasil coating has lasted this long and the compressions are still good, it is unlikely to fail. It has been reported that, following the removal of the problematic sulphur content fuel, bore wear on nikasil engines is now often less than engines with standard steel liners.
I see that Croatian Crodux fuel is categorised as “sulphur-free” as it meets the European standard EN 228 for low sulphur content (under 10 ppms) which is as good, if not better than the fuel it will have been running in the UK.
Old Oct 11, 2018 | 07:01 AM
Neven's Avatar
Thank you so much for the encouraging and supportive message dear Graham. Crodux is my favorite and I have good experience with their fuels.
In respect to listing my vehicle(s), I must admit I am a bit reluctant because I do not own any Jag so far, although that is my desire since childhood and I intend to fulfill it a.s.a.p., searching intensively for an elderly but not too much aged Jag in good condition. All I found so far are those with V8 engines 1999 (XJ8 and XJR) or 2000 (S-Type). They all have at least 100.000 miles but seem to work perfectly although they were not registered for years but kept in garage.
Otherwise I have quite nice cars, but since none of them is a Jag, I do not think these should be listed.
Kindest regards, sincerely yours, Neven
stetson1
Jan 1, 2015 05:46 PM
Stu 1986
Nov 29, 2012 02:14 PM
unionjack
Jan 14, 2011 09:21 PM
gwhiz101
Oct 18, 2010 08:15 PM
martinweston
Aug 29, 2008 11:34 AM
