Really need help jag s type 2000 3.0 v6
Old Feb 23, 2024 | 10:23 PM
Tyrjager17's Avatar
Default Really need help jag s type 2000 3.0 v6
I was driving my car and it’s just died as if the key was just turned of. So I initially thought it was the gas pump so I tested it and it was getting gas but I don’t have a compression test to get the actual specs but I tested the valve and gas shot out,however I couldn’t hear it prime so I just figured I throw a new one in mind you I check all wiring and fuses and relays my inertia switch I checked it all I checked spark so I put a new gas pump in anyways just to make sure. But the new one doesn’t prime either… so now I’m wondering if it could be a camshaft or crankshaft positional sensor but the only problem is no matter what I do I cannot find where these sensors are every schematic is a different engine except for one. Which has a completely different looking sensor the the part on the website for my car so I have no clue what to do now. And through all of this I have no engine light and it just cranks. I tried reading it with my nt7500 scanner I believe is the model and no luck any suggestions!
Old Feb 24, 2024 | 02:20 AM
Welcome to the Forums.
You are not saying where you are, BUT, the use of "gas" has me at US of A.
I suggest a re-ask in the S Type (X200) Tech Section.
There has been a thread recently regarding the Fuel Pump Drive Module, maybe??
Good luck
reznik6044
Jul 10, 2018 09:13 AM
Noel619
Apr 4, 2016 08:18 AM
buickfunnycar.com
Oct 5, 2015 02:41 PM
Jaguar3
Aug 16, 2008 02:36 PM
mrhayat
Feb 12, 2008 05:27 PM
