Rear Seat Back Removal
Old Dec 17, 2012 | 06:38 PM
ggsharples's Avatar
Default Rear Seat Back Removal
After removing the two bolts from the bottom of the rear seat back, what else needs to be removed to remove the back from the car?
ggsharples--1965 3.8S
Old Dec 17, 2012 | 11:23 PM
plums's Avatar
Your post has been moved to its own thread as it has nothing to do with the thread on brake hose material.
You would have the best luck in getting an answer by posting in the model specifc area of the forum for your particular area.
Old Dec 18, 2012 | 03:35 AM
There's two rear seat assemblies listed for the 3.4S and 3.8S depending on Chassis Number but the removal procedure is the same for both.
Lift the rear seat cushion upwards off the two locating pins at the rear of the seat and remove the cushion.
Remove the two screws and washers securing the bottom of the rear seat squab to the back of the seat pan. Lift the squab to disengage the three retaining hooks and withdraw the squab.
Follow this link MKI / MKII S type 240 340 & Daimler - Jaguar Forums - Jaguar Enthusiasts Forum to the tech section for further help, advice and information.
Attached Thumbnails Rear Seat Back Removal-s-type-seat-parts.jpg   Rear Seat Back Removal-s-type-seat.jpg
BritCars
Oct 15, 2019 12:28 PM
RaceDiagnostics
Dec 11, 2015 10:12 AM
xk8don
General Tech Help
Aug 29, 2015 11:10 AM
dpappyp
Aug 27, 2015 06:31 AM
divingmom
Aug 25, 2015 07:54 PM
