SDD battery monitor
Old Mar 6, 2022 | 01:14 AM
Curtiss2009xk's Avatar
Default SDD battery monitor
While using SDD some sessions work fine other have popup saying battery voltage is zero. Battery icon is always half pink half red. Torque app shows battery at 14v at obd connector also i have 13.8v 30 amp power supply connected. This must be a software issue?
Old Mar 6, 2022 | 08:03 AM
clubairth1's Avatar
Community Influencer
Again and again we see this. What are you using as a power supply? Note power supply NOT battery charger!
You need a 50A, 13VDC+ low ripple power supply. Until you have one hooked up to the car you are headed for big problems!
All the SDD stuff should be added to the current giant thread on this forum. Search for the SDD threads and post on them. They are huge and old. Tons of information are in those threads but it will take some time to read thru them. Otherwise it's all scattered about and the same things are repeated over and over.
Old Mar 6, 2022 | 08:21 AM
resolved my expensive mongoose cable from GB didnt
Work. My cheap knockoff works fine. Battery with 30 amp power supply stays green car is a 2009
Colin21958
Oct 29, 2021 10:04 AM
rlouisa
Apr 14, 2021 03:55 PM
Patrick Wong
Aug 8, 2017 02:14 PM
Naso--Lituratus
Apr 2, 2015 10:44 PM
ejjbee
General Tech Help
Nov 25, 2012 02:06 PM
