SDD Pinpoint Tests
Old Jun 7, 2017 | 05:27 AM
8bit's Avatar
Default SDD Pinpoint Tests
I'm trying to resolve a couple of issues on my car just now, one being a MAF related code. SDD (v131) is suggesting I run a pinpoint test related to that code.
What does this do - does it just guide the operator through checking specific pins on specific connectors for volts/resistance and give a diagnosis there, or can it test bits of the car itself to work it out? Is it safe enough to do, obviously with an approved interface cable and a battery support unit attached?
Old Jun 7, 2017 | 05:55 AM
Cambo's Avatar
Pinpoint tests are only possible with a VMM.
Old Jun 7, 2017 | 07:35 AM
8bit's Avatar
Ah OK, thanks for that.
Old Jan 24, 2019 | 02:54 AM
Xnodrk's Avatar
Sorry to raise the deads but is there a cheaper alternative nowadays to VMM ?
Old Jan 24, 2019 | 03:42 PM
Sean W's Avatar
Some of the pinpoint tests identified in the service manual can be done with a standard voltmeter but obviously depends on the tests. Other than that, what Cambo said...
Old Jan 24, 2019 | 03:46 PM
Xnodrk's Avatar
Ok thx i gonna look but i need first to pinpoint technical info about pinpoint test for x type my2009
