Tyre pressure monitoring system fault
Old Apr 24, 2020 | 01:06 PM
Chris32111's Avatar
Default Tyre pressure monitoring system fault
does this mean I need new sensors in the tires ??
Old Apr 24, 2020 | 01:25 PM
Welcome to the forums Chris,
If you had started in the usual way by posting an Intro in https://www.jaguarforums.com/forum/n...-intro-must-5/ telling us something about yourself and your vehicle, you would have been directed to the relevant model forum to post this question.
Old Apr 24, 2020 | 01:35 PM
Chris32111's Avatar
Thank you.
Old Apr 24, 2020 | 05:21 PM
Chris,
It appears this is a current (2009 onwards) model XJ.
The sensor batteries have approximately a five year life so the age of the vehicle will tell you if this is a possible cause.
When the TPMS system detects a malfunction, the dash warning flashes for approximately one minute and then remains continuously illuminated. This sequence continues on subsequent vehicle start-ups as long as the malfunction exists. If the sensor batteries are OK and you haven't had a recent wheel/tyre change then over inflating by about 5 psi and dropping the pressure back to normal can often clear the TYRE PRESSURE MONITORING SYSTEM FAULT message.
Old Apr 24, 2020 | 05:29 PM
Chris32111's Avatar
where is the battery sensors located ? Would like to change the batteries and try that way.
Chris,
Old Apr 24, 2020 | 05:40 PM
There is an individual battery on each sensor inside the wheel. The tyre has to be removed to access the sensor and the batteries are non-replaceable.
I recommend you take the question to X351 forum for advice from members with the same model. Don't forget to add MODEL YEAR details as the system is slightly different on later models.
para911
49
Feb 8, 2022 07:35 AM
vaibhav
Jun 18, 2020 07:49 PM
DPierce388
Oct 2, 2019 05:53 PM
zaye
Mar 31, 2015 04:45 AM
