Wanted: Genrad WDS Cables
Old Mar 27, 2023 | 12:10 AM
heima's Avatar
Default Wanted: Genrad WDS Cables
Hello,
I am looking for cables for the Genrad 3500 WDS PTU.
Particularly:
A-204 = 418-F232
or
A-401 = 078-00601
B-203 = 418-F231
B-259 = 418-F557
or
B-280 = 418-F558
If you are willing to part with one, several, or many, please let me know.
Thank you much, Matt
Old Mar 27, 2023 | 09:17 AM
motorcarman's Avatar
The only cables that are required for communication for Jaguars (OBDII) to about 2006 are the A-204(A-401) and the B-203.
The VID block cars can use the B-259 or B-280 but a B-203 is satisfactory and will substitute.(the early cars usually won't recognize the B-259/280 cables)
Old Mar 27, 2023 | 12:21 PM
heima's Avatar
Right, Thank you for confirming.
The B-259 or B-280 is for other than Jaguar, IE Ford and Mazda.
Perhaps someone has a dysfunctional PTU, but still useable cables? Please let me know.
Thanks, Matt
Old Sep 19, 2024 | 08:46 AM
tlindi's Avatar
Thanks, Matt
B-280 is upgrade to replace B-203 and can be used instead. B-259 is the same but shorter. 280 and 259 came from Ford WDS but are compatible with Jaguar. WDS even on UI says you to connect B-280 and use B-203 if you don't have 280. 280 is "must have" with newer cars with VBLOCK (onwards 2002 or so).
Last edited by tlindi; Sep 19, 2024 at 08:54 AM. Reason: Added image of cables from Ford and Jaguar WDS manuals
Griff79
Jan 14, 2023 12:37 PM
Paulc732
Aug 26, 2017 01:44 PM
nebelfuerst
General Tech Help
Sep 20, 2014 02:07 PM
steadicam
Jun 18, 2014 11:39 AM
Crispy
General Tech Help
Dec 18, 2011 06:48 PM
