WDS Hard drive died
Old Nov 25, 2023 | 05:12 PM
rrosscoe's Avatar
Default WDS Hard drive died
Evening all from Boston England, I have a working WDS for my XKR which luckily I have not had to use in anger for a long time (fingers crossed not tempting fate) and I also have one for FORD, Bit of a long shot but had need to use my ford one the other day and found that the system would not boot, long story short looks like the hard drive has corrupted, I know a few members have FORD units as well was wondering has anybody in my neck of the woods a copy of the ISO's for the i believe 4 ford disc's that i could obtain please.
Regards
rrosscoe
Old Nov 25, 2023 | 07:29 PM
xalty's Avatar
sell the piece of junk to somebody with a vanquish or a db7v. $20 mongoose with legacy ids tools is faster and does everything you need for an x100 except reflash ecms which you'll never need to do anyways.
Old Nov 25, 2023 | 07:44 PM
motorcarman's Avatar
He is looking for FORD WDS (probably Version 43) software to get his FORD WDS working again.(not Jaguar)
Old Nov 26, 2023 | 07:03 AM
rrosscoe's Avatar
Default WDS Disc's again
Morning all,
an update to my post I have just found a BLUE copy of B45, will this install the basic ford software ? there is conflicting info some say this is installed first others no.
Regards
rrosscoe
Old Nov 26, 2023 | 08:18 AM
You need an 'A" disc first, (GHOST) then a 'B' disc.
I use A6, B43 and C5. (in that order)
Old Dec 3, 2023 | 06:44 AM
rrosscoe's Avatar
Default Thank you
Ah ok, will do that if and when I can obtain the missing ISO's or Disc's, It's Very strange that both Hard Drives seem to have failed at same time, the PDU works fine as replaced Ford for Jaguar HD and works as should. One says no RAM? the other sys cannot find operating system (or somthing like that) put one in old laptop and it boots into Windows 98! so just do not know what the answer is
Thank you for input
rrosscoe
Old Dec 3, 2023 | 08:09 AM
I gave up on regular Hard Drives and went with 4 to 8gb Compact Flash Cards and a 44 pin adapter.
The mechanical HDs are getting hard to find and fail more often.
Old Dec 14, 2023 | 08:08 AM
rrosscoe's Avatar
Unhappy update
Well I certainly need the disks now as my instrument cluster went for repair and came back as (hard fault cannot repair) so now on lookout for replacement panel which I will need to have synced to the key and PCM, so anybody with the disks or link to ISO's out there please, Reminder it is for FORD WDS, I have the Jaguar one.
rrosscoe
MRomanik
Non-Jaguar Vehicles
Jul 29, 2023 11:58 AM
Apr 24, 2019 04:57 AM
Ngarara
May 10, 2015 09:17 AM
CorvetteZ51
Jun 4, 2008 11:51 AM
CorvetteZ51
May 28, 2008 02:08 AM
