Welding safety?
Old Jul 4, 2018 | 02:55 PM
Segfault's Avatar
Default Welding safety?
Somewhat off topic. I need to do some welding, using MIG. Perhaps someone can suggest what is the best inexpensive fire extinguisher to keep around?
Old Jul 4, 2018 | 03:47 PM
abonano's Avatar
Be sure to disconnect both neg and pos terminals of the battery on the vehicle. My bud welded something (I forgot) on his car and took out his CPU amongst other things.
Old Jul 4, 2018 | 03:56 PM
Segfault's Avatar
Actually I believe the safest is to disconnect the positive from battery and connect it to the ground. This will short out all impulses that may be generated by welding. Also, the ground lead of the welding should be as close as possible to the welding point to reduce risk of parasite circuits.
Edit: The question was about fire extinguisher. What type of extinguisher does not expire too fast and is effective? CO2?
Old Jul 4, 2018 | 09:13 PM
abonano's Avatar
Probably any small unit that is easily reachable should suffice. CO2 would be a good choice.
I think the shelf life is about 3 - 5 years.
NJ2003XJ8
May 19, 2017 01:48 PM
03Xtype
61
Jun 30, 2012 05:49 PM
mark campbell
Dec 1, 2011 02:03 PM
CJNetrider
Oct 15, 2011 09:48 AM
08Z06
Jan 11, 2011 11:35 AM
