Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Sponsored by: CARiD
headliner removal
Old Mar 14, 2011 | 01:33 AM
Jag Breeder's Avatar
Default headliner removal
Does anyone know how to remove the headliner in a 01 s type
Old Apr 9, 2011 | 11:13 AM
scars's Avatar
to be honest i dont think theres a way without bending it....i just redid mine with all the pillars im about to put it back
Old Apr 14, 2011 | 03:22 PM
What all did you have to take apart
Old Apr 15, 2011 | 04:52 PM
scars's Avatar
Visors handle bars ...and pop out the rear lights....u have to remove a pillars and loosen b and c pillars
Old Apr 16, 2011 | 05:19 PM
And that's all thanks
Old Apr 17, 2011 | 07:42 PM
Anyone have a more definitive "how to" write up c/w pics / vid for this one?
Might be a good time to do it if there's anyone out there as I don't think there's one on site at present?
Old Oct 1, 2011 | 11:11 AM
Jochem00's Avatar
Not sure if you can get the headliner out through the trunk, otherwise you have to remove the front windshield.
It's a pretty straight forward job the remove the A B C pillar covers, handlebars lights, sun visors.
If you have to go throught the front windshield, you need a special wire cutter to gut throught the window sealant, for which you need some experience not to cut through the glass.
I replaced my headliner in my XKR 2 months ago in less then 2 hours, but that one goes throught the door. but there you have to take out the rear seats and passenger seat.
Old Mar 30, 2012 | 06:17 PM
I finally got time to get my headliner out and it was a piece of cake it did come out perfect through the trunk now time to put my fabric on it thanks for the tips
Old Oct 25, 2012 | 01:18 PM
Jochem00's Avatar
I replaced my stype headliner yesterday evening, made some pictures which I will post soon.
And indeed the headliner goes out through the trunk. Very straight forward. Putting back in took less then an hour. I used a lighter to melt the glue for the wiring harness which is attached to the headliner.
Noticed that the velcro around the sunroof was not doing what it is supposed to do anymore.
Old Oct 26, 2012 | 01:35 AM
Jochem00's Avatar
Pictures
Attached Thumbnails headliner removal-img_1085.jpg   headliner removal-img_1086.jpg   headliner removal-img_1087.jpg   headliner removal-img_1088.jpg   headliner removal-img_1089.jpg
headliner removal-img_1090.jpg   headliner removal-img_1091.jpg   headliner removal-img_1092.jpg
Old Oct 26, 2012 | 02:41 AM
Lou'S's Avatar
Default 2005 S-Type Headliner
Hi Jochem,
My S-Type is a my 2005, and it also needs renewal of the cloth, colour "champagne", but I cannot (yet) find a supplier for the foam backed cloth in this colour.
Two questions:
1) Could you manage to put the renewed headliner back in without kinking it? My S-type has a sunroof as well.
2) Do you have the name of the company that made the cloth you used?
Old Oct 26, 2012 | 12:22 PM
Jochem00's Avatar
To take it out and put back in you rwally have to bend it and put a kinck in the board. When I took it out I thought, wtf this is not going to work but pushed it through anyway as I did not have much time to do the work. But with the new cloth on and putting it back into the car I do not notice any lines at all.
I thought the original headliner was grey but faded over the years but the new grey cloth is really grey and not the correct color as it has to be more beige/champagne. I will probably redo the headliner again in the future but had to leave the country again for a project abroad. So No I do not have the right color yet.
I might try this one Tissu Revêtement velours ciel de toit automobile SAM04 - Boutique Du Tapissier-Simili cuir-Tissu d'ameublement-étoffe-Tissu Revêtement automobile-Ciel de toit-Mousse de polyuréthan-Mousse tapissier-Outillage du tapissier-Meuble tapisée-www.bouti
Which is a company in germany. i might order a sample from them but I will not see my stype forthe coming 2 months
By the way, when you apply the new cloth, cut in the holes for the handle bars straight away so you have to stretch the cloth less in these areas. Same around the sunroof area which is very tight.
Old Dec 31, 2014 | 07:19 PM
RobGardnerBlack's Avatar
Variation on the same theme, I took mine in and out via the right rear door with the passenger seat all the way forward.
By pulling up the rear parcel shelf there is a green multi plug that allows the headliner card come out with all the wires attached; a little more time to access but keeps the wires in place.
I took the advice of Jochem00 and cut the holes in the headliner for the handles and sun roof which did make the job easier.
I went with black as I have an STR and it appropriate with the cream and black theme. The sunvisors are shot and I am unable to cover these so will source a newer set via a recycler here in Sacramento.
Attached Thumbnails headliner removal-img_20141230_204337744.jpg   headliner removal-img_20141230_204344042.jpg   headliner removal-img_20141231_102003447_hdr.jpg
Jose
Dec 18, 2021 08:16 AM
Tony K
Apr 2, 2020 11:55 AM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
SoCalJagS
Sep 13, 2015 07:13 PM
graham11
Sep 7, 2015 03:04 PM
