Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
V8 SC Engine oil ways
Old May 19, 2013 | 05:25 PM
marky68's Avatar
Default V8 SC Engine oil ways
Trying to find out if the 4.2LTR V8 SC engine has a removeable main oil gallery bolt on the block anywhere for the purpose of fitting an external oil accumulator?
Old May 19, 2013 | 09:05 PM
plums's Avatar
subscribed.
There are passages in the cylinder head at the rear that have plugs in them. Whether they are oil or coolant is not apparent.
Plugging them is part of the head assembly process detailed in the 4.0 engine build manual.
Another alternative is the oil cooler lines, but the inlet is thermostat controlled.
There is also the oil pressure sender port.
Old May 28, 2013 | 12:54 PM
RSR Racing's Avatar
[QUOTE=marky68;740003]
[/QUOTE
If you are looking to accomplish this without drilling and tapping, the plug in the rear of block (bellhousing face) leads directly to main galley, and is probably the best location for the introduction of "emergency" oiling. Unfortunately, this means splitting the engine from trans and modifying the plug to accept whatever fitting you have on the accumulator.
Old May 29, 2013 | 05:04 AM
marky68's Avatar
Hi the engine is out and on a pallet so access isn't a problem, but I couldn't see any removable plug anywhere on the block at the rear?
"the plug in the rear of block (bellhousing face)" bell housing mating face?
I will take a picture and pop it up here for comment.
[QUOTE=RSR Racing;745796]
[/QUOTE
Attached Thumbnails V8 SC Engine oil ways-42ltrstyperengine16_zpsc70d2e50.jpg
Old May 29, 2013 | 05:48 AM
avos's Avatar
Its the large alen bolt just above the crank, behind the flywheel/starterwheel
Old May 29, 2013 | 12:35 PM
RSR Racing's Avatar
Just behind the flywheel. Possibly modify the plug for a Banjo type fitting and route through the valley.
[QUOTE=marky68;746198]Hi the engine is out and on a pallet so access isn't a problem, but I couldn't see any removable plug anywhere on the block at the rear?
Old May 29, 2013 | 12:51 PM
SteveM's Avatar
Originally Posted by plums
subscribed.
Are you talking about the 4 threaded holes at the back of the heads? Does oil/coolant actually come out of them?
Old May 29, 2013 | 12:58 PM
RSR Racing's Avatar
These passages are for cam journal oiling, and to the best of my knowledge are not open on every engine variant (not sure about 4.0L). Regardless of this, accumulator oil introduced here will not reach the main bearings. There are check valves (typically pressed into cylinder head) inline from the block's oil path in this circuit.
Old May 29, 2013 | 01:14 PM
SteveM's Avatar
I removed one of the plugs (fairly sure it was only one) because the other holes were not plugged and I figured why have extra weight if it's not necessary, lol. I'll check if any oil leaks out when it's running.
Old Jun 3, 2013 | 01:05 AM
marky68's Avatar
Thanks, RSR,
I'm not sure I can use that one as the custom manual flywheel will be pretty close to it and therfore not leaving much room for a banjo.
The other option is at the oil filter housing but i cannot find a oil sandwich adapter plate to fit the large jaguar oil filter thread anywhere?
Old Jun 3, 2013 | 07:36 AM
RSR Racing's Avatar
Understood regarding the flywheel. I am not aware of anyone that sells an oil filter adapter for that application. Seems like a very simple part to make though.
Have you considered a remote filter mount?
Thanks, RSR,
Old Jun 5, 2013 | 01:52 AM
marky68's Avatar
I don't think a remote filter is going to help and I guess finding the oil filter end cap to send the oil to this will not be off the shelf either.
The two things I'm trying to achieve are getting a reserve oil supply back into the engine where it will be useful to prevent oil surge ( is it even an issue with these engines?)
Secondly somewhere to take off oil pressure and temperature senders for aftermarket gauges.
As I am running an aftermarket ECU is it possible to remove the factory senders pictured here and replace with others?
This bolt on filter and oil cooler housing has caused me alot of grief whilst trying to fit a larger bottom pulley I have approx 3mm clearence with the new pulley fitted after some careful grinding of the housing. I won't be able to change charger belts with the housing fitted that is for sure. ( new pulley not pictured yet)
Attached Thumbnails V8 SC Engine oil ways-42ltrstyperengine5_zpsa30fa26e.jpg
Old Jun 7, 2013 | 09:42 AM
RSR Racing's Avatar
Please see my replies in red:
I don't think a remote filter is going to help and I guess finding the oil filter end cap to send the oil to this will not be off the shelf either. I can now see from the pics what you are dealing with.
The two things I'm trying to achieve are getting a reserve oil supply back into the engine where it will be useful to prevent oil surge ( is it even an issue with these engines?) I do not believe there are substantial issues with oil surge in these engines. Typically a reserve oil supply is for priming on startup, situations where the chassis outperforms the oiling system (high G loads), and emergencies where something in the oiling circuit has failed.
Secondly somewhere to take off oil pressure and temperature senders for aftermarket gauges. Maybe removing the sump, and drilling your own ports would be best.
As I am running an aftermarket ECU is it possible to remove the factory senders pictured here and replace with others? As long as the stock sensors have no function in your application.
Old Jun 7, 2013 | 07:56 PM
Arland Green's Avatar
RSR Racing! Are Paul Gettilozzi and Reteif Goosens and the team working on an 'F' type variant to race ALMS? I saw the team at Road America 3 or 4 years ago with those stunning lime green and black GT XKR's.
Old Jun 10, 2013 | 07:28 AM
RSR Racing's Avatar
Currently there are no plans to race the F Type. RSR is currently racing a prototype in the ALMS, and Retief Goosen is presumably working on his golf game. Marc Goosens is driving one of the SRT Vipers at LeMans.
BrentGardner
29
Dec 16, 2024 12:13 AM
DavidNagel
Dec 29, 2017 09:16 PM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
dpappyp
Aug 27, 2015 06:31 AM
