Jaguar Forums Feedback & Suggestion Center Need help with Jaguar Forums? Ask here! Have a suggestion to help improve Jaguar Forums? Tell us here....THIS SECTION IS NOT FOR TECHNICAL QUESTIONS
Pic missing
Old Nov 24, 2012 | 11:31 AM
trebor12's Avatar
Default Pic missing
Just noticed my signature picture is missing, it's there in my profile but won't upload....am I missing something here?
Bob
Old Nov 24, 2012 | 11:45 AM
Which pic Bob, I'll try to help you out?
Old Nov 24, 2012 | 05:26 PM
Bob,
The usual problem is trying to load a SigPic over the size limit of 50 x 100 pixels or 9.8 KB (whichever is smaller).
If this is the case with the SigPic you want to use, you'll have to use photoediting software to save the image within these limits.
My SigPic is from a 3MB original saved as a 6KB image.
Old Nov 25, 2012 | 05:38 AM
trebor12's Avatar
Thanks to you both, it's odd really, I've had the SigPic since I joined and if I look in "edit my sisnature" it's there (not in dialogue box but below) and states it's my current SigPic. It's in my "album" and it's the same pic "in my Garage" I've also noticed that has been deleted from my signature in all my posts....hummmmmm
Bob
Old Nov 25, 2012 | 06:13 AM
Bob
Bob,
Any changes to your Sig affect all your posts and not just ones made after a change. This explains why the Pic has disappeared from all your posts and doesn't appear in older ones
The Pic in the garage is within the right limits for a SigPic and, as you say, it is showing in your "edit my signature"
I've copied it from your garage to my PC and will try uploading it here as a check:
Old Nov 25, 2012 | 06:17 AM
Originally Posted by GGG
........................ I've copied it from your garage to my PC and will try uploading it here as a check..............
That worked in post #5 above so there's nothing wrong with the Pic image.
You could edit your Signature to upload the Pic from your PC and it should fix things...........
Old Nov 25, 2012 | 06:28 AM
trebor12's Avatar
Thanks Graham, I'll give it a try
Bob
Old Nov 25, 2012 | 06:33 AM
trebor12's Avatar
Yep that worked, thanks again Graham
Bob
BadKat174
May 26, 2023 12:29 AM
King Charles
Apr 16, 2017 11:10 AM
pilot435
Apr 8, 2016 06:16 PM
neckstrap
US Western
Sep 10, 2015 10:44 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
