Mark V - X 420G 1948 - 1970
420G high idle
Old Jul 20, 2020 | 11:47 AM
bear747's Avatar
Default 420G high idle
Hi,
1967420G as of yesterday has very high idle......rev counter not active so can't be precise. However, higher and loader than when it normally starts with the choke. Reduces when I shift into gear but returns to high when in P or N.
Any thoughts??
B
Old Jul 20, 2020 | 05:04 PM
Fraser Mitchell's Avatar
Have you done anything in the engine bay recently ? First off I would check the throttle cable is returning to the idle position fully.
Old Jul 20, 2020 | 07:41 PM
bear747's Avatar
Hi Frazer
No I have not. I will do so tomorrow and see if that corrects the issue
Old Jul 21, 2020 | 08:39 PM
bear747's Avatar
All linkage is free and working
Old Jul 22, 2020 | 05:11 PM
Try disconnecting the cold start carburettor. I am assuming this high-revs idle continues even when the engine is warm ?
Old Jul 24, 2020 | 01:16 PM
bear747's Avatar
Hi
By disconnecting , how, what do you mean? .... Just want to avoid messing with wrong aspect + how to test etc
THx
Old Jul 24, 2020 | 04:23 PM
As your car is a US version, can you say what carburettors you have. I would expect there to be an automatic enrichment device, but US cars may be different. A photo might help.
Old Jul 24, 2020 | 09:13 PM
bear747's Avatar
Hi
Please see attached
Old Jul 25, 2020 | 05:00 AM
If you look between the top and middle carbs you'll see the AED device with its aluminium-coloured strap with a lttle securing screw at the top. That device is switched electrically. You might care to consider removing the whole of the induction side and to dismantle the carbs and rebuild with a rebuild kit.
The Worlds Sole Manufacturer of Genuine SU Parts - SU Carburetters
You might care to have a read of this as well
https://forums.jag-lovers.com/t/salo...-choke/35482/4
Old Jun 11, 2021 | 03:31 PM
thorswhisper's Avatar
Vacuum Leak. Check manifold gaskets, especially to carb bodies.
Lightweight
XJ40 ( XJ81 )
Jun 4, 2018 03:31 AM
al_roethlisberger
Mar 8, 2018 10:35 AM
Joshua skinner
Feb 22, 2018 10:11 PM
Spikepaga
Jul 19, 2017 03:53 PM
Jagxjs
Mar 15, 2013 05:00 AM
