Mark V - X 420G 1948 - 1970
Oil pipe on MKV 3 liter
Old Apr 30, 2019 | 09:33 AM
dirkroels59's Avatar
Default Oil pipe on MKV 3 liter
Hi,
I'm looking for information regarding the oil pipes on a MKV 3 liter engine.
I have a MKV without engine, so I located a correct spare engine, however on the oil pipes I have some unclear view.
If starting from the oil galery under the carburators, you see a T connector coming out the oil galery.
One side goes to the oil gauge, but I have no clue where the other goes to.
Anyone who can help with a picture or some explanation????
Dirk
Old May 1, 2019 | 03:44 PM
Fraser Mitchell's Avatar
Well, based on the later XK engine, maybe it is a feed to the cylinder head to lubricate the valve rocker shaft. However, normally feeds to push-rod engine valve gear don't have the oil at gallery pressure normally its downside of a pressure feed to a bearing.
Old May 2, 2019 | 06:11 AM
Coventry Foundation's Avatar
Dirk do you mean a 3.5L engine?
Old May 3, 2019 | 04:03 AM
Yes, indeed the 3.5 liter straight six, that was original to the Jag Mark V from 1950.
Old May 3, 2019 | 04:37 AM
Right--will check the SPC. THe reason the size of the engine was asked was you stated it as a 3 L engine.
Old May 3, 2019 | 06:17 AM
Yes, sorry my mistake.
I Appreciate very much your help.
dirkroels59
Mark V - X 420G
Oct 2, 2017 04:58 AM
Steve Croasdale
Mark V - X 420G
23
Apr 7, 2016 01:20 PM
classic1945
Mark V - X 420G
Mar 30, 2015 04:22 PM
Nos_Monkeys
Aug 6, 2013 04:04 AM
Jack Rabbit
May 29, 2007 11:22 AM
