Mark V - X 420G 1948 - 1970
Timing marks on Auto Mk VII 1953
Old Mar 20, 2015 | 03:07 AM
hsv587's Avatar
Default Timing marks on Auto Mk VII 1953
Hi all,another newbie question coming up,but you mob are very helpful,and might have a better idea than me.
Where are the timing marks on an auto mkvii jaaaag? .
I know on the manuals its on the flywheel,but I cant see no obvious inspection plates or anything on the top of the auto bellhousing,only the cover underneath..i thought i would post here before i pull the bottom cover off to inspect the flexplate.
I couldnt see anything obvious near the harmonic balancer,but its pretty grotty down there,and not much space to see anything.
Ive already done a google and forum search,but ive turned up nothing so far...
Old Mar 20, 2015 | 09:03 AM
Jagfixer's Avatar
Driver's side. Look over steering column to bell housing. this side of engine stabilizer should be a hole. There is a line on bellhousing that you line up with flywheel thru the hole. Timing is 5 BTDC.
Old Mar 20, 2015 | 02:37 PM
motorcarman's Avatar
Driver's side and passenger side is a rather useless term when describing British cars.
Just sayin'.
bob gauff
Old Mar 21, 2015 | 03:38 AM
hsv587's Avatar
I had a better look with my torch and found it ..lined up the marks,and pulled the dizzy out..once my new points and condenser arrive ill pull it appart,clean it,and reassemble it .
Sprayall
May 30, 2021 08:13 AM
PMKimpton
Aug 3, 2019 08:22 PM
Sprayall
Sep 3, 2015 07:49 PM
pnwrs2000
Sep 3, 2015 11:55 AM
XFR_Gold
Sep 2, 2015 12:24 PM
