Staggered set of 20" Kasuga wheels off my CPO XJ
For SaleWheels and Tires/Axles
Description:
This set of wheels came off my recently purchased CPO 2014 XJ supercharged sedan when I replaced them with a set of polished Orona wheels. They were redone by the dealer's wheel person as part of the CPO process, as they all had some curb rash and/or small cosmetic flaws. They are not bent or welded, and ran straight and smooth when I swapped them out. I would rate them an 8 out of 10. You can see some slight differences in the sheen and finish where they were sanded and sprayed. Unfortunately the day before swapping them out I slightly curbed the right front wheel at the very outermost edge. $950.00 for the set, plus shipping.
Sounds good. Just let me know if you need any other info. I’m pretty sure that the kasugas fit the XKR starting with the 2010 facelift and chassis changes, but not the earlier ‘07 - ‘09s which had a different offset. I think they used them on some special editions like the XKR175, and the speed packs. Came across several images of them when I was looking for new wheels for my 2011 XKR coupe, which I traded on the XJ supercharged. Allan
Hi - I’m afraid I don’t know if they will fit or not. I don’t think I’ve ever seen a set of the kasuga wheels on an F-type. I can tell you the fronts are 20x9” & 49 offset, while the tears are 20x10” & 46 offset. If you find they will work let me know. Thanks for the interest.
