1961 Mk2 3.8 Restoration
Old Mar 15, 2017 | 07:24 AM
  #121
csbush's Avatar
Bummer on the rust. It is all fixable of course. just kind of a PITA.
Old Mar 15, 2017 | 09:31 AM
  #122
gene61jag's Avatar
That's a fact - haha. This will definitely require welding to fix
Old Mar 15, 2017 | 09:37 AM
  #123
gene61jag's Avatar
Replaced the door locks yesterday. Initial tests were good but the driver's side needs adjustment before the door cards go on.
Old Mar 15, 2017 | 02:49 PM
  #124
TilleyJon's Avatar
Looks like that rust is in the front footwells, there is a repair panel for that area. it is normally around/above the jacking point, which you may need to remove too to facilitate the repair, just look at it as more welding practice !
Old Mar 15, 2017 | 11:38 PM
  #125
gene61jag's Avatar
Unfortunately I have never welded, and I have no welding equipment. I know there are a few places on the body that will need to have metal replaced. Apparently I'll have to add this to the list :P
Old Mar 17, 2017 | 09:52 AM
  #126
gene61jag's Avatar
I have finished installing locks (barrels) and I'm down to 2 keys. Essentially I got most of my information from the Jaguar Manual and a handful of inspiration from old(2013) entries from this forum. And I used copious amounts of PB Blaster(love that stuff!) Pics I took are mostly too dark and too close-up to distinguish but I will post what I did if requested.
Old Mar 28, 2017 | 12:57 AM
  #127
gene61jag's Avatar
Last time I took the car out (weekend before last) my acceleration was horrible, it seemed to me that I had to rev very high to accelerate at all, and at the end of the drive I noticed my oil pressure was way down. Pulled over, and when I checked, oil was low.
Got me thinking that if I'm burning oil my compression might be down. So I checked that today. I doubt that I have done it completely right but here's what I came up with:
Cylinder
6 - 120
5 - 120
4- 150
3 - 150
2 - 140
1 - 145
Assuming these are good readings for a 3.8L how does this compression compare? What do you read into these numbers?
Old Mar 28, 2017 | 01:44 AM
  #128
TilleyJon's Avatar
Gene
on those readings compression is down on 5 and 6 and a little low on 2 but not terrible, try the checks again to make sure you have correct readings, then you could try a leakdown test to try and isolate the issue, hear is a good article on how to perform this if you don't know.
https://mobiloil.com/en/article/car-...-leakdown-test
Old Mar 28, 2017 | 06:18 AM
  #129
Jose's Avatar
Jon,
I tried to get you the measurement, but can't get to it without raising the front of the car on a lift, can 't even see the tie rods ffrom the front or from the rear from either side.
Old Mar 28, 2017 | 09:04 AM
  #130
gene61jag's Avatar
Thanks Jon and Jose. It's been over 20 years since I've done a compression test on anything. Very unnerving to listen to - the old girl sounded like she was writhing in pain
Glad I remembered to disconnect her fuel pump before starting
Old Apr 24, 2017 | 04:58 PM
  #131
gene61jag's Avatar
Been about a month so I reckon I better let y'all know I haven't been a total slacker.
During the last month I have taken the car down to the shop that I want to do a lot of the interior and exterior work. They did the following:
- Tuned the engines and carbs. Their lead mechanic says the carbs "were not that bad"
- Replaced forward suspension bushings and shock absorbers
- Replaced leaky heater valve
Went to a local tire place
- Replaced 40(?)-yr-old tires
And this past weekend I personally changed the differential gasket and diff oil
I'm talking with a transmission shop about fixing my automatic transmission. It works, but it lags a bit more than I want.
Old Apr 24, 2017 | 07:09 PM
  #132
sov211's Avatar
Will it be ready for Jaguars on the Island in Victoria, July 28? There is usually a good showing of early saloons and I'll have my 66 3.8 on the field.
Old Apr 25, 2017 | 08:06 PM
  #133
gene61jag's Avatar
No promises man. She is far from being complete. She's a runner(sorta) but she needs a full interior, body & paint. I will tell you, I have every intention of getting her on the road as soon as possible. But I have a fairly long list of stuff that has to be fixed before I get her out there.
Thank you for the invite though. It helps to motivate me
Old Apr 26, 2017 | 01:36 PM
  #134
csbush's Avatar
"She's a runner" ---Well that is a plus I have a long ways to go to even get there!
Old Apr 27, 2017 | 09:51 AM
  #135
gene61jag's Avatar
I have had a lot of help. A LOT of that help and support has come from this forum. Thank you!
Progress: Last night I pulled out the wooden dash (two 7/16 nuts and a light) and the after-market tape deck someone installed in the 80s.
Old May 4, 2017 | 02:14 PM
  #136
gene61jag's Avatar
Mile 47917 - Yesterday I drove down to get my fire extinguisher inspected/recharged, then drove over to ascertain what size wheels/rims I will need to order(I need 15x5 wheels). Then I drove a box of parts that I'm not likely to use for a while down to storage.
She did well, but my oil pressure gauge showed low pressure as the engine got hot. Everything else seemed fine for short trips.
Old May 4, 2017 | 02:27 PM
  #137
Jose's Avatar
use Castrol 20W50 engine oil, nothing but.
Old May 4, 2017 | 02:38 PM
  #138
gene61jag's Avatar
This corroborates what a mechanic told me - that a higher high-temp viscosity will be good. Guess it's time for an oil change Thanks Jose!
Old May 4, 2017 | 05:28 PM
  #139
Jose's Avatar
You welcome Gene,
when I bought my XJ-6 in 1989, I went to the local Jag expert and started picking his brain (of course), he told me the same thing, nothing but Castrol 20W50 in XK engines, not Mobil, not Exxon, no synthetic oil, nada, nothing but Castrol.
Old May 5, 2017 | 01:27 AM
  #140
littlelic69's Avatar
I know that feeling!! After four or so years of restoration, my engine, Daimler V8, ran - Oh, the joy!! Congratulations, congratulations, and more. It is great when you have done it yourself!!
