3.8s type backfiring through carbies
Old Sep 21, 2020 | 03:33 PM
  #61
wouldbeowner's Avatar
PS the backfiring was due to a crook sparkplug. The problems with the carbies were that it was running rough.
Old Sep 21, 2020 | 06:51 PM
  #62
Glyn M Ruck's Avatar
I actually think you will find it was a combination of lean running on acceleration & a duff plug.
Old Sep 21, 2020 | 07:30 PM
  #63
Quite possibly Glyn.
Old Sep 22, 2020 | 02:41 AM
  #64
Peter3442's Avatar
Indeed, lean mixtures need a much more energetic spark. The problem is then partly fuelling and partly electric and, as you have experienced, very difficult to diagnose.
Old Sep 22, 2020 | 08:41 AM
  #65
Yep! SU's have no throttle pump & depend on slight opening of the jet & delay in piston rise to create depression over the jet & thus to achieve enrichment & provide the throttle pump effect. Having an air leak beyond that on the shafts would nullify this not helped by a duff plug. Thus running lean on acceleration & backfiring.
My experience noted previously in this thread with a split pipe on the LHS tank/pump was hell to diagnose as we appeared to have good air free fuel flow at the front feeding the carbs. We had a number of good minds trying to diagnose including an old technical chap that used to work at Brown's Lane (said Lyons could be a difficult man to work for.) It flummoxed all of us until we found the split pipe by a process of elimination. We made the classic mistake of jumping to conclusions ~ e.g. It must be the Pertronix Ignitor ~ let's go back to standard points which at least eliminated that as the cause. And let's check the valve timing which I knew to be correct.
It's one thing having the knowledge ~ but quite another applying it to diagnosis and doing a physical repair with the required skill in that regard.
e.g. I would go to a specialist to ream the carb bodies to accommodate oversize butterfly shafts. I would not trust myself to do the job, neither do I have the required equipment.
wouldbeowner
23
Aug 31, 2020 01:00 AM
Rdp
Dec 3, 2018 10:57 AM
lunagry
Sep 21, 2014 12:35 PM
rrmillsap
XK120 XK140 XK150
Mar 22, 2014 11:18 PM
police666
Dec 8, 2011 07:30 PM
