Bonnet heat shield
Thats really interesting Bill cos my temperature gauge reads normal but engine bay get stinking hot. Has extra complication of being a 4.2 with trple SUs. Im going to install an electric fan and see if that helps dissipate heat!
the fact that the engine bay appears to be abnormally hot, yet the engine temp is reading normal is good. if the gauge is accurate (easily determined with an inexpensive laser temp gun) it would mean to me that the cooling system, especially the thermostat, water pump and radiator, is doing its job. and if so, what are the disadvantages you are having with what appears to be the excessive heat in the engine compartment? for instance, are the rubber parts aging prematurely, is there a problem with vapor lock in the carbs or fuel lines?
regardless, i'm assuming the fan's purpose would be to disperse hot air from inside the engine compartment at idle or at very, very low speeds only. and not provide additional engine cooling inasmuch as you've observed no engine overheating.
i guess, forgive me, that i'm questioning the purpose of an additional fan.
I would take a guess and say 60 to 90% of the heat in the engine bay is coming from the exhaust manifolds. Putting a fan on the front of your radiator is a complete waste of time and money in this case. Try heat wrapping the exhaust manifold or getting the exhaust manifolds ceramic coated to reduce the heat. Better long term investment than a useless fan in the front grill pushing cold air through a hot radiator which heats it up adding more heat to the engine bay.
I agree you have extensive knowledge of heat under the bonnet but not Jaguar real world heat. Your 500 BHP V8 is not Jaguar real world. It is possibly producing twice the heat a standard 3.4 / 3.8 is producing (twice as many headers to start with) so what you have done is commendable for your installation but not required for 95% of the real world Jaguar sedans out there.
Do you not find that by forcing all your hot air out of those holes in the sides of the inner wings that your tyres and brakes don't over heat? Do your feet not get extremely hot in the foot wells?
And please tell me you have not added LED strip lights in your wheel arches!
I have no issues with the brakes, nor feet getting hot
Oh but I have added LED strips in the wheel well, under the chassis which are on a manual switch
Thx. Yep, the idea is to get a bit more air movement to try to remove some of the engine bay heat. I had vapour lock last week on a relatively cool (25 deg C day). Will take the car for a spin next week and see if my hardwork has made any difference!!
I do believe that just some type of ram air scoop in the front even without making cuts into the inner fender well will help the airflow somewhat and more than other things. You can paint it black and it will look like an air dam or front valance but having it angled up so the air is scooped to then go around the engine will help force some air out of the Jaguar's oven of an engine bay. As I said that air scoop did the most for all of this heat.....
