Clutch has no hydraulic pressure
Old Sep 13, 2022 | 02:18 PM
jrosenfeld's Avatar
Default Clutch has no hydraulic pressure
My 1959 Mark 1 had a slow clutch fluid leak. Now the pedal has totally has lost pressure. I haven't found a mechanic nearby to either rebuild or replace the clutch cylinder. I live near Fort Worth, Texas. One said you must drop the transmission to get at the clutch cylinder. Does anyone have advice about this?
Old Sep 13, 2022 | 03:42 PM
JeffR1's Avatar
A new vehicle with a standard have a concentric slave cylinder that is mounted in the centre of the bell housing; that needs the trans dropped to get at it, but not the Jaguar, it's simply mounted on the side, and is operated with a fork.
Whom ever told you that doesn't know what they're talking about, and if that person is a mechanic, I wouldn't go there.
Old Sep 13, 2022 | 04:06 PM
jrosenfeld's Avatar
Thanks Jeff. That's good news.
Old Sep 13, 2022 | 05:27 PM
Cass3958's Avatar
Even an amateur mechanic with an adjustable spanner can remove the slave cylinder from under the car in ten minutes. Buy a new set of seals or even a new slave cylinder and you could have it back on the road in an afternoon.
Old Sep 13, 2022 | 05:28 PM
Glyn M Ruck's Avatar
Clutch slave cylinder Right Hand Side of bell housing and easily accessible. For easy bleeding nipple up.
Old Sep 13, 2022 | 06:43 PM
jrosenfeld's Avatar
Thanks Cass!
Old Sep 13, 2022 | 06:44 PM
jrosenfeld's Avatar
Thanks Glyn!
Duke85
Aug 9, 2020 02:36 AM
bobanddoug
Jul 20, 2017 04:17 PM
Qvhk
Jun 6, 2017 10:41 AM
xtype62
Jul 20, 2016 12:17 PM
Nardoswiss
Jun 3, 2012 11:20 AM
