Conversion to Serpentine belt
Old Oct 3, 2007 | 04:06 AM
Cadillac's Avatar
Default RE: Conversion to Serpetine belt
You did an outstanding job ! A '50 Mark V owner tried to install A/C in his car but due to insufficient room he couldn't do that . Your project sounds cool too . Good luck with your project
Old Oct 3, 2007 | 09:14 AM
Jose's Avatar
I have seenan aluminumcrank pulley with serpentine belt adapted to MK-II and S type, but not the XJ-6 pulley. Mine is a 1965 S type. However, my 1984 XJ-6 does not have such a serpentine pulley, so you might be referring to a more modern XJ-40 ??
And, are you saying thatduring stop-n-go traffic, the Pusher Electric Fan in your car, cannot keep up ?
Talk to Rock Browning at Mr. Jaguar/Retro Air www.mrjaguar.comand see what he says; He works with MK-II, S type, and 420 retrofit air conditioners.
Also, I have been hearing that adding a "splash panel" under the front of the car, (same as in the 1980-1987 XJ-6), improves the temp. situation in these old Saloons.
let us know what you do. I'm interested myself.
Jose
Old Oct 3, 2007 | 02:27 PM
Jose's Avatar
check here:
http://www.classicjaguar.com/pulley.html
I don't have pics of the splash panel - this was beingtalked aboutas a "theory"to curethe overheating in the MK-II. You would have to look at a splash panel in a Series 3 XJ-6 to understand what it entails, it's a flat panel covering the open area under the radiator and up to the front member.My S type does not have a splash panel but it doesn't overheat, even in stop-n-go traffic. (but I don't have A/C).
Pulley: I recall another company, but they are in the UK, and they manufacture the custom serpentine belt pulleys. I'll keep looking for them.
Jose
Old Oct 4, 2007 | 10:43 AM
Jose's Avatar
yes, Rob Beere was the place I was looking for. They have a website showing all their engine parts. Rob Beere Engine Components.
Old Oct 4, 2007 | 12:16 PM
Jose's Avatar
glad to be able to help, though I'm not always able to...
great news about the pulley! For consultation and advice, I know a Jaguar technician who might help. He has 30 years experience and recently broke the land-speed record in Daytona with his Purple E-type, a car which he built.
Call Tom Curren at (407) 298-1358. his shop is called Coventry Classics in Orlando, Florida. Heworks with MK-II, S type, 420, and all other Jags. I plan to have himwork in my 3.8 engine in the future. I think hecan help you with the belt routing and other issues.
Jose
Old Oct 4, 2007 | 07:25 PM
Jose's Avatar
I don't think that's Tom's website, and as far as I know he doesn't have one. Yes, he's still in biz, I just spoke to him a week ago. He has a shop in Orlando, full of Jaguar engines and transmissions stacked to the ceiling in giant racks. I remember that CCC website, they showed a list of classic parts, and you had to request a "quote" by e-mail, and then they never replied. Definitely not Tom's style. Give him a call.
Old Nov 20, 2014 | 09:06 PM
Bo Tant's Avatar
Piggy back pump on alternator, sanden ac compressor, couple brackets manufacturer and a single pivot pulley can run hole setup with one belt.
Old Nov 21, 2014 | 09:11 AM
Jagfixer's Avatar
Some MKIIs had A/C dealer installed. I picked on out of a breaker's yard with the condenser in boot. Compressor was mounted vertical and low. Seems the PO did not use antifreeze and car was scrapped because of freeze break on block. I am planning on restoring condenser and using in MKI with the new style compressor that is small an electric powered.
Old Nov 21, 2014 | 10:03 PM
JPG's Avatar
JPG
An alternative is to use an electric pump for the power steering and keep the single belt setup (although with a longer belt than standard).
JP
Old Nov 22, 2014 | 07:57 AM
primaz's Avatar
If you can find someone whom will fabricate it I think that is your best bet. Expect to pay some money but keep in mind serpentine belt set ups once they are engineered often sell of about $1800 or more that come with the power steering pump and AC compressors. Even my resto-mod 3.8s with a GM v-8 had to require a serpentine belt set up which was about $1800 and came with billet brackets/pulley's and chrome power steering, alternator, and power steering pump. Thus don't freak out if the custom work is expensive. I am using electric fans to push and pull through a Wizard custom radiator and with the AC on a hot day everything is running cool.
MrWhite
19
Jun 14, 2022 07:49 PM
04Xjrsteve
May 7, 2019 04:06 PM
Col. Sandurz
Sep 28, 2015 07:29 PM
42Ajd
Sep 26, 2015 07:04 PM
