Extracter Speedometer Drive Assembly(C11929)
Old Nov 18, 2019 | 01:58 PM
Jagmk21964's Avatar
Default Extracter Speedometer Drive Assembly(C11929)
Hello,
Any suggestions to how I find or make the tool for extraction of the Speedo drive assy on Compact type A OD? It is the same connection as on Type A OD.
in advance thank you.
jagmk21964
Old Nov 18, 2019 | 08:54 PM
Glyn M Ruck's Avatar
Should not be necessary once you have loosened the clamping bolt.
https://www.jaguarforums.com/forum/m...l-leak-223822/
If stubborn attach an old speedo outer cable & give it a tug.
Old Nov 19, 2019 | 02:49 AM
Jagmk21964's Avatar
Thanks, I'll try to see if I can find a suitable one for doing that.
Old Nov 19, 2019 | 09:51 AM
Jagmk21964's Avatar
Evrything went well. The speedo pinon came loose after a light tug. Thanks for advice.
georgeryoung
XK120 XK140 XK150
May 7, 2019 06:08 AM
NathanDD6
Jun 7, 2016 07:31 AM
adenshillito
Feb 27, 2016 02:05 PM
Series1fan
Jan 10, 2016 09:58 AM
nanny ogg
Jul 6, 2015 07:15 AM
