Front seat belts (again!)
Old Apr 1, 2024 | 09:03 AM
Rishi's Avatar
Default Front seat belts (again!)
Sorry to have to ask, I have searched as much as I can but still not absolutely sure how to approach this.
I have decided that I do want front seat belts in my 1965 3.8 MOD.
I have XJ6 Mk1/2 seats mounted.
I want inertia reel belts as static belts are too limiting in movement.
I very nice lady at FDTS is helping me put together some belts that will be reasonably fitting with the era of the car, I don't want stalks I will go with a classic buckle.
If I understand correctly there is a floor mount under the B pillar and another mounting point low on the B pillar?
This is the inertia reel I will be using.
Should I mount these direct to the B pillar or use a bracket and mount to the floor under the B pillar?
Looks like I should mount against the B pillar and use the floor mount eye bolt for the lap strap?
Rishi
Old Apr 1, 2024 | 10:58 AM
Jose's Avatar
are those 3-point belts you want to install ?
if yes, you only need the B pillar top mounting or "pivot", and the B pillar bottom mounting for the reel.
The third mounting is on the opposite side of the seat by the transmission tunnel for the receiver part.
Old Apr 1, 2024 | 05:28 PM
Cass3958's Avatar
To mount the inertia reel on the bottom of the "B" pillar you will need to make a bracket so it sits over the top of the sill. I saw this bracket on an original Mk2 at a show and decided to copy it. If you mount the inertia reel to the floor then you either cannot slide the seat back or forth or the inertia reel is placed on the floor behind the seat restricting the foot well for rear seat passengers getting their feet in and out of the car. Ask me how I know.
These are some photos of the bracket I made (I doubt if you will find an original one) which I installed into my car.
This is the original position I fitted the inertia reel but it restricted the rear foot well space.
These are the brackets I made.
The brackets sit over the sill. The eye bolt goes through the base plate whilst the top is bolted to the "B" pillar.
The Inertia reel then sits on the bracket and is bolted to it.
Even using this bracket there is not a lot of room between the side of the seat and I had to remove the reclining handle to allow the seat to be able to slide backwards and forwards.
The inertia reel bolted to the bracket.
Old Apr 2, 2024 | 01:41 AM
Rishi's Avatar
Thanks. These foto’s are really helpful. My reel has a single mounting point so I should be able to mount it directly to the B pillar. I do have reclining levels so I had better check the clearance. Otherwise I will have to go with static belts.
Old Apr 2, 2024 | 03:22 AM
Peter3442's Avatar
As I recall, my reel box was made for mounting on a vertical panel. We attached it to the bottom of the B post. We added a steel plate to spread the load. With standard (very wide) Mk2 recliners it was a tight fit.
As Rob wrote, if we'd used the canonical point on the inner sill, it would have conflicted with the seat. That location works only for belts without a reel.
Old Apr 2, 2024 | 03:34 AM
Cass3958's Avatar
Personally I would not mount it bolted directly and only to the bottom of the "B" pillar. The mounting point on the floor, which mine is attached to where the eye bolt is, is a factory fitted fully strengthened mounting point where as if you bolt it to the bottom of the "B" pillar the metal there is thin and weak and in an accident you could very easily pull the bolt out of the "B" pillar giving yourself no protection except in a low speed accident. You will note on mine that I have a single 8mm bolt going into the "B" pillar through a convenient hole that was already there but this is just to hold the top hard against the pillar and is not a securing point. I also found that when I mounted the bracket and put this top bolt in there is only just enough room to get your fingers in through the hinge hole to put the nut on the back of the bolt. Trying to mount the reel on the "B" pillar and getting behind the pillar to mount a suitable large securing nut and a strengthening plate would in my opinion be almost impossible.
The mounting points on the floor. top of the "B" pillar, under the back seats and on the rear parcel shelf of my car are all factory fit and I have a plate under the bonnet on the inner left wing that states they comply with BS AU 48 1965. I would not mount seat belts anywhere else other than these points without extra strengthening plates being fitted.
Old Apr 2, 2024 | 03:50 AM
Rishi's Avatar
This is good food for thought. Maybe I will just go with statics. A little less convenient but sounds like it will be easier. I am also worried that my reclining levers will get in the way. Need to go and take some photo’s today and make some measurements.
Old Apr 2, 2024 | 06:38 AM
Peter3442's Avatar
Seat belts that don't retract are going to be long term painful. As XJ seats are much narrower than original Mk2, it should be possible to fit a reel. For loads, there are probably some standards that don't apply to old cars. I'd think in terms of a 100kg passenger and a momentary 10g deceleration giving about a tonne force. A tonne shouldn't be a problem to carry as a transient load. However, think about load paths; try to put loads into panels as shear rather than at right angles to panel. Good structural design works if all the joints are ball joints, all the angles are hinges, and all the bolts are undone.
Old Oct 12, 2024 | 03:12 PM
85lc's Avatar
Default Front seat belt anchor point near tunnel
I need to know where the seat belt anchor points are located for the front seat belt near the tunnel. I assume that there is a welded nut either near or on the tunnel that would accept an eyebolt for teh seatbelt.
I had someone install the interior kit on my 1963 MK2 and they covered the anchor points for the seat belts that are near the tunnel.
The two outboard eyebolts near the B post were installed before they installed the carpet.
What I would like to see a photo of the interior (tunnel side) showing where the seat belts are anchored. Even a sketch or description would be very helpful.
Thank you,
Roy
Old Oct 12, 2024 | 03:15 PM
85lc's Avatar
Also does anyone have recommendations for a nice 3 point seatbelt.
Old Oct 12, 2024 | 03:33 PM
Rishi's Avatar
I will take some pictures of mine for you. I managed to find all the mountings and install eye bolts. I would recommend cleaning the threads with a tap before installing the eye bolts. I got them from FDTS Ltd.
Old Oct 12, 2024 | 04:07 PM
Jose's Avatar
in my '65 S type, the tunnel eye bolts are installed 3.5" inches from the rear of the seat because otherwise they would interfere with the rear movement and reclining of the front seats
This measurement was taken with the front seats in a normal position, not with the seats fully forward.
Old Oct 12, 2024 | 05:41 PM
Cass3958's Avatar
Here is a picture showing the floor of my S Type and clearly shows the location of the seat belt eye bolts in the floor at the base of the "B" pillar and at the side of the propshaft tunnel.
Old Oct 13, 2024 | 09:42 AM
Rishi's Avatar
I choose statics as I am going to replace these seats with some original Mk2 recliners that are a little bit wider. I am fairly tall so I have no issues reaching everything without having to undo the belts.
Old Oct 13, 2024 | 10:13 AM
Jose's Avatar
I installed static belts too, no problem with them. I kept the original BMC static belts to fit them to the rear seat.
Old Oct 13, 2024 | 10:25 AM
Peter3442's Avatar
Note that on Rishi's car and my Mk2, the floor locations for seat belts are about 7 or 8 cm to the rear of those on Cass's S type. I don't know if that's a matter of year of manufacture or model.
Rishi - the interior of your car is looking very good.
Jose - pleased to see that you survived the hurricane. I hope your friends, family, and motor cars are all fine.
Old Oct 13, 2024 | 11:23 AM
Rishi's Avatar
Thanks. When I have the Mk2 seats back in and my new wood installed it is going to be even better. Sometimes I am not sure about the seat rwplacement. These are lovely seats and very comfortable but they
just don’t look quite right.
Just gave her a good wash. She has to perform in a few weeks as a wedding and honeymoon car. My wedding!
Old Oct 13, 2024 | 12:30 PM
Jose's Avatar
Peter,
Thank you. The famous Milton hurricane was more hoopla than expected.
I live inland away from the coasts, at airplane altitude, so no flooding or catastrophic anything happens here.
(Florida is not entirely flat).
By the time the wind and rain arrived, it wasn't even a Category 1 storm.
My neighbors and I remained in our homes.
I spent the night inside the garage polishing the XJ-6 chrome, the S type chrome was done during hurricane Helene 3 weeks ago.
85lc's Avatar
What is a good source fro static 3 position seat belts?
I bought a pair years ago and they look more appropriate for a old Ford Pinto. The mounting hatrdware for the B column is covered by a very cheap, thin plastic cover.
Old Oct 13, 2024 | 12:33 PM
Jose's Avatar
that triangular cover is all you get nowadays.
I got mine from Sports & Classics:
https://sportsandclassics.com
Chas256
Jan 28, 2024 03:12 PM
iramphal
Dec 19, 2022 05:56 PM
rgp
Jan 19, 2022 02:14 PM
ruffindustries
Dec 12, 2021 04:24 PM
kuba9449
Jan 19, 2015 02:57 PM
