fuel cap gas cap
Old Apr 25, 2019 | 08:43 PM
jagstuart's Avatar
Default fuel cap gas cap
has anyone found an after market fuel/gas cap for the 3.8 S? I'm looking at the Stant 10623 or 10640. These are fitting the XKE and MX 4.2. Mine were not present when I got the car. Looking for something cheaper than $80 for the pair.
Old Apr 25, 2019 | 10:41 PM
Glyn M Ruck's Avatar
https://www.ebay.co.uk/itm/Fahler-Po...EAAOSw8w1X4ANC
Old Apr 25, 2019 | 11:05 PM
jagstuart's Avatar
thanks glyn
Old Apr 27, 2019 | 04:00 PM
jagstuart's Avatar
found this at the local O'Riellys for 7$. Summit with shipping is about the same. Took tank in and it's a perfect fit though vented which won't really matter (good if your vent pipes are crudded up).
https://www.summitracing.com/parts/s...RoCIZ4QAvD_BwE
Old Apr 28, 2019 | 07:15 AM
Coventry Foundation's Avatar
Jagstu you need vented up to 1970 MY
Old Apr 28, 2019 | 01:50 PM
TilleyJon's Avatar
That one is unvented according to the second Q&A and then further down it says it's vented !
Make sure you get this correct or you may run out of gas along the road !
Old Apr 28, 2019 | 04:56 PM
jagstuart's Avatar
the 1966 3.8 S has vent tubes on the tanks. made sure that metal lines from inside the neck and then second one down the tank to bottom were nice and clean before reinstalling tanks.
Old Apr 28, 2019 | 07:10 PM
Correct! The S Types have a complex venting system on their tanks & don't use vented caps. The long looped nylon tube (7) is apparently required for proper operation. Don't shorten. (longer in real life than shown in diagram)
Old Apr 29, 2019 | 07:15 AM
Oddly enough the SPC calls for a vented cap.
Old Apr 29, 2019 | 09:34 AM
Old Apr 29, 2019 | 10:44 AM
That might be so but many of the cars did not come with vented caps as they don't need them. It is possible it changed at some time. There are plenty of errors in the SPC or where it varies from reality. I have my restored originals fitted ~ unvented. The reproductions are now vented much to the disgust of us originality freaks. They drilled a hole in the damn things.
Reproduction:
Old Apr 29, 2019 | 10:50 AM
Argh ~ screen started scrolling in the middle of this now A about F post.
Above is what my SPC says. I will take a pic of my caps when I get around to it. They look the same as the repro sans hole.
Old Apr 29, 2019 | 12:29 PM
Interesting. I am very familiar with vented and non and they are usually marked underneath (non vented marked NV). I checked the J12s (Master parts list) and it looks like a non vented cap came on board as a new part in 1966/67. Oddly enough there were 2 of them--C23601 and C23601/1 although it does not say what the difference is. Both cost $3.41 at the time. What is more interesting to me is the vented cap C 17566 cost $1.92 at the same time! Must have been an expensive hole to drill! I did see Bulletin C 24 where there was some issue with the vent tubes on the 'S' in or around Dec. 64. There was also an issue about the same time with the Vent on MK2 becoming clogged by road dirt. Interesting as my son's 340 (all original) and my 420 G (I am the second owner) both have vented caps. I will take a look at all of the caps I have and see how many non vented have been drilled after the factory. I would guess that would be much faster than replacing vent lines or cleaning vent lines.
BTW what version of the SPC is that you posted--or is it from an A1 list?
Old Apr 29, 2019 | 02:46 PM
I have many S Type SPC's but the one I snipped out of is Revision November 1970 that I had to hand electronically. My car is A1B56966DN. So way after cap C23601 was introduced. Number 4 produced at CDA East London. Came off the line very late 1965.
Old Apr 29, 2019 | 03:59 PM
TilleyJon's Avatar
My S Type SPC August 1964 shows the same info as the one you snipped Glyn
C23601/1 appears to have been used on the E-type Series 2, not put the effort in to find out the difference on the /1
Old Apr 29, 2019 | 06:54 PM
Could be but FED S2 E types were vented until 1970. These caps were introduced in 66/67. Also odd our SPC is the Aug.64 ed. but no change on caps.
Old Apr 29, 2019 | 07:06 PM
Cap C23601 was introduced in S Type production way before 66/67. As an example 1B50966 (RHD) was built in mid 1964 as was 1B75437 (LHD).
Old Apr 29, 2019 | 09:38 PM
GLYN the J 12 says later.
Old Apr 30, 2019 | 12:38 AM
TilleyJon's Avatar
Which J12 ?
Old Apr 30, 2019 | 01:29 AM
Actually from what I know of fellow club member cars I believe the SPC to be correct with Chassis numbers effective from.
