Fumes in the cockpit
Old Oct 16, 2013 | 07:11 PM
davey69's Avatar
Default Fumes in the cockpit
Engine has been out of my Mark 1 recently and when it was put back together the engine breather is currently attached to the LH inner guard and the outlet is aimed down low where the front rail meets the firewall. While this provides great rust proofing (!) I suspect it is contributing to a fumey, acrid burnt oil smell in the car. Hoping to see a photo and /or advice on the correct setting of the engine breather hose. Does it attach directly to the engine block and point straight down towards the road?
Old Oct 17, 2013 | 03:38 PM
Fraser Mitchell's Avatar
Surely the engine breather pipe goes to the inlet manifold after the oil separator ? The oil separator used to be at the front-top of the engine.
Old Oct 17, 2013 | 05:14 PM
davey69's Avatar
Thanks for the reply but on the early engines (eg. XK120s and Mark 1s) the breather is just a pipe to the outside air.
Old Oct 18, 2013 | 04:19 AM
jaguar38s's Avatar
Hello,
Just let the breather pipe go to a Breather filter.
That will work fine.
And if the enigine is fine you will not see any fumes at all.
regards,
Peter Jan
dsnyder586
Dec 29, 2024 07:39 PM
Jaguila
Sep 5, 2015 06:16 PM
sleepycat
XJ40 ( XJ81 )
Sep 13, 2012 07:50 PM
in2town
XJ40 ( XJ81 )
Apr 20, 2009 08:41 AM
