Gas Pedal Angle
Old Jul 29, 2024 | 06:43 PM
Felixbobcat's Avatar
Default Gas Pedal Angle
I removed the throttle rod that connects my gas pedal to the carburetors linkage. I need to put it back together and can't find any information about the gas pedal angle. I've got a left hand drive car.
Old Jul 29, 2024 | 07:19 PM
cdg66mk2's Avatar
I just completed this job last week. The first attempt was very wrong. The pedal was way down with the throttle plates closed. I loosened the clamp on the rod and bumped a screw driver in there to hold it open. From the inside of the car, I pulled the pedal back up to where it looked like it should be at idle. There is a mechanical stop that prevents the pedal from going completely vertical and I was close to that position.
Making sure (again) that the throttle plates were closed, I pulled the screw driver out of the clamp and tightened the clamp bolt.
I don't have a seat in my car so I can't tell if the pedal position feel "normal" or not but it looks to be about right.
Hope this helps.
Craig
Old Jul 29, 2024 | 07:47 PM
Glyn M Ruck's Avatar
Most Throttle pedals with rollers 10. ~ Post early pendant pedal.
Late throttle pedal more progressive with link 6.
Old Jul 29, 2024 | 07:57 PM
Refresh page.
sony2000
May 30, 2025 03:38 PM
Pisara
Aug 31, 2021 06:10 AM
Portlander
May 31, 2021 04:02 PM
toronadomike
Oct 16, 2013 04:53 AM
whoisjongalt
XJ40 ( XJ81 )
Oct 7, 2008 09:12 PM
