loose ends (wiring)
Old Jan 13, 2019 | 05:59 PM
jagstuart's Avatar
Default loose ends (wiring)
I spent the morning putzing with the dizzy wiring. Seems the internals were a bit worn frayed and possibly shorting? Got that done, but now more loose ones:
I'm assuming the green/black wire inside the black sheath goes some where near the choke solenoid (if I've pegged that part right, that is) but I can't find a male terminal plug anywhere around it.
wire is green/black female terminal plug
Got the two green and green/purple ones sorted (brake switch). The yellow/purple one's got me stumped. Horn?
yellow/purple with female terminal plug
Old Jan 13, 2019 | 06:14 PM
Glyn M Ruck's Avatar
Green & black goes to the Otter switch. Purple & yellow goes to the horn solenoid Terminal C1 or to one of the horns. Note that some cars had their horns wired via the ignition & some not.
Old Jan 13, 2019 | 10:16 PM
jagstuart's Avatar
https://www.jaguarforums.com/forum/m...-et-al-212613/
glyn - pretty sure you nailed the otter switch with the post above and yes the wire in the harness branch with the coil leads was it. this one in the vicinity of the choke solenoid is too short to have reached the otter switch. I'll just get the multi tester out and find the other end I hope. . . Also the car has been After Market wired for a period electric pushing cooling fan to help out the AM A/C unit, so there is some extra stuff and non stock wires in the harness (well next to the harness anyway). thanks for the pics, very helpful.
Old Jan 13, 2019 | 11:17 PM
Then it's the throttle switch for the anti creep valve I presume. You have an Auto.
EDIT: Jaguar could have used another wiring colour to save confusion!
Old Jan 14, 2019 | 02:37 PM
TilleyJon's Avatar
The shortage of wire colours was probably down to saving cost rather than confusion Glyn, if you look at the old Lucas wiring colours and their uses, there is some kind of obscure (very) logic honestly there is !!!
Old Jan 14, 2019 | 05:12 PM
I have to say that the total re-harness/wire of my car went pretty smoothly. Gave my guy a Fluke meter with audible continuity beep to make working single handed easier when I was not in town doing the nerd manual paging & diagram gazing. It also helped that my upholstery man is a qualified aircraft instrument fitter. When my man doing the grunt work got confused with the windscreen wiper circuit while I was in Cape Town he stepped in & sorted that very quickly.
I'm used to modern CANBus/Network communication in cars & SAMS.
Old Feb 10, 2019 | 04:36 PM
Ponysnake's Avatar
Default Similar paths
Stuart, I seem to be about one month behind you, in trying to get a long sidelined MK2 started up.
I am having the same issue with those pesky Green w/blk wires and the Starter Carb/Auto Choke.
Were you able to put a terminal on your broken Green w/blk wire that was IN with the White Coil wire, and wire it up to the Otter Switch?
​​​​​​​Did the Starter Carb function properly wired this way?
Old Feb 10, 2019 | 11:09 PM
jagstuart's Avatar
switched to working on the fuel supply. tanks, lines, pumps etc. i'll let you know when i get back to the front end. - stu
Old Feb 11, 2019 | 02:55 PM
TilleyJon's Avatar
If you check for continuity between the green/black at the aux starter carb and the green black in with the coil wire you should have continuity, if so it should then be connected to the Otter switch, this creates the ground path when the Otter switch is closed and energises the aux carb solenoid, this of course assumes the Otter switch and solenoid are both working.
Paul B. Kim
Oct 4, 2017 03:13 AM
Bruce Caulley
Nov 15, 2015 10:40 PM
Spikepaga
Sep 13, 2013 11:35 PM
ez53436
Audio/Visual Electronics
Jan 20, 2012 11:17 AM
Oct 28, 2010 11:12 AM
