Mark 2 brakes not release after new system installed
Old Apr 15, 2019 | 02:34 PM
JohnnyMacc's Avatar
Default Mark 2 brakes not release after new system installed
Haven't done much troubleshooting yet but figured I throw the issue out here anyway. I recently finished rebuilding/replacing the brake system on my Mark 2. Drove out of the driveway and after a few taps realized brakes were not releasing. The work completed to date includes new master, new lokeed booster, wilwood front upgrade, rear cylinder/handbrake refurbishment, and some new lines. Had to crack a line coming out of the booster to release pressure to get it back in the driveway. Thanks for any two cents in advance.
John
Old Apr 15, 2019 | 07:45 PM
Glyn M Ruck's Avatar
If Auto check the anti creep valve & circuit.
Can also be the servo. Sticking/tight main vacuum piston seals or air valve sticking.
Good luck!
Old Apr 16, 2019 | 05:53 AM
JohnnyMacc's Avatar
Last night we did some more troubleshooting and when we removed the vacuum hose no locking so definitely something with the booster. I might put the original booster back in as it may be fine.
Old Apr 16, 2019 | 06:43 AM
Funny ~ when I got up this morning I was thinking about it & was going to suggest you pull the vacuum hose but you beat me to it.
Old Apr 17, 2019 | 06:20 AM
JohnnyMacc's Avatar
Good News! Removed the Lockeed booster and replaced with one of the original units I had, bled the systems and I now have functioning brakes that don't lock up on their own. Guess the old saying if it aint broke dint fix it rings true again. I may send out another original unit I have to be rebuilt at some point. Test drive planned after work.
John
Old Apr 17, 2019 | 06:27 AM
JohnnyMacc's Avatar
Old Apr 17, 2019 | 09:42 AM
Good news! Damn servos/boosters.
Old Apr 29, 2019 | 09:55 AM
JohnnyMacc's Avatar
The old booster failed too. Expecting a new refurbished unit in the mail today from XKs unlimited. Ordered a new reservac valve as well. Going to take the opportunity to replace the last few lines I hadn't previously as well.
Found another related post on the Jaguar Enthusiasts forum as well: https://jec.org.uk/forums/viewtopic.php?t=6633
Stand by for updates......
Old Apr 29, 2019 | 05:56 PM
I presume you are not messing around with Silicone Brake Fluid? It can cause severe elastomer compatibility issues.
Old Apr 29, 2019 | 07:43 PM
JohnnyMacc's Avatar
Nope using synthetic.
Old Apr 30, 2019 | 01:32 AM
Please use good old conventional DOT 4 Polyglycol/Polyglycol ether fluid. You are likely causing your own problems with boosters unless the rebuilder/supplier guarantees compatibility of elastomers with fluid. "Synthetic" can mean many things with many different seal swell & other compatibility issues.
klintous
Apr 15, 2022 10:44 PM
mikchek
May 8, 2019 11:38 AM
Gaelic 12
UK & Eire
Apr 30, 2018 05:49 AM
cdmarano@gmail.com
Aug 24, 2009 07:09 AM
May 7, 2007 05:06 PM
