Mk1 build
Old Sep 20, 2020 | 01:40 PM
  #61
DaimlerMK2's Avatar
Hi
have a look at fitting your discs over the hubs as per they are now on cars
and not as bolted on the back of the hubs as they are now
Old Sep 20, 2020 | 01:43 PM
  #62
notenoughtime's Avatar
Originally Posted by DaimlerMK2
Hi
what gain will this give?
Old Oct 6, 2020 | 12:59 PM
  #63
Not much to add but the dash arrived, what’s the best way to restore the wood?
Old Oct 6, 2020 | 02:44 PM
  #64
JeffR1's Avatar
If the veneer is intact, a small compressor, a good quality air brush and automotive clear coat.
You will also need a dry place to work, a bunch of disposable in-line water traps for the compressor, and a full face respirator.
Old Oct 6, 2020 | 03:02 PM
  #65
Homersimpson's Avatar
You need to remove the old varnish, I used paint stripper and a stanley knife blade and slowly scraped it off.
Then as above I used 2K car laquer, loads of coats to fill the grain then flat and mop it like car paintwork.
Old Oct 6, 2020 | 05:21 PM
  #66
Glyn M Ruck's Avatar
You might wish to read from post #35 here:
IMHO Low VOC nano ceramic automotive clearcoats are also a good choice. Spraygun Devilbiss GFG-670 Gravity Plus. Compressor IR industrial unit. Model unknown. We had excess bone dry air. We were working in a very low humidity area of the country anyway.
Don't be shy to do minor grain touch ups with varying colour stains & small art brushes etc to hide damage etc. should you have any prior to applying lacquer. All the pros do including British Autowood that is probably the best out there.
Great care should be taken not to sand through the veneer on edges etc.
https://www.jaguarforums.com/forum/m...2/#post2002815
Old Oct 11, 2020 | 03:21 PM
  #67
I was offered a mk2 jag this weekend and couldn’t refuse
few pics but until arrives not sure what I’ll do with it
Old Oct 11, 2020 | 03:44 PM
  #68
I saw this up for sale a while back, think it was on eBay. At that time if had a load of panels with it and one was a complete chassis rail so it might need a fair bit of work underneath.
Looks a good project.
Old Oct 11, 2020 | 11:46 PM
  #69
Early 2.4 from steering wheel & dash manual choke.
Old Oct 12, 2020 | 12:16 PM
  #70
not sure it was on eBay, came out of a barn and been there a good few years apparently
Old Oct 12, 2020 | 12:19 PM
  #71
‘63 2.4 manual
I’ll add some pics once it arrives on weds
Old Oct 15, 2020 | 12:23 PM
  #72
This was it a few years ago when I first saw it on ebay but it was relisted recently either on e-bay or on another website stripped like it is now with a load of panels including a complete new chassis leg. I can't find a link to that one.
https://nl.pinterest.com/pin/3393181...c_v2=1a1p2T3Ah
It looks fairly rotten but if you love welding as much as I do that would make a good challenge!
Old Oct 15, 2020 | 12:46 PM
  #73
I don’t mind a bit of welding lol
Old Oct 15, 2020 | 12:49 PM
  #74
thanks for that, for what I paid I think it was worth it however rotten it is lol
Old Oct 15, 2020 | 01:17 PM
  #75
I’ve found this from the link you shared
https://www.ebay.ie/itm/BARN-FIND-Vi...-/163051875667
that was back in 2018
Old Oct 16, 2020 | 04:07 PM
  #76
Chassis rails look good, just rear outrigger/ jacking point not good and left inner arch
think I might just weld it up as it really doesn’t look that bad I’ve seen and repaired much worse (see pics above)
if if I can get the engine running then that is definitely the plan
Old Oct 16, 2020 | 04:52 PM
  #77
Front of inner rear arch not great but nothing that cant be sorted
Gauges and switches in good condition
Chassis rails
Old Oct 18, 2020 | 01:27 PM
  #78
Guess I’ll have to start another project page as I’m going to weld this one back together, it may not be a concourse resto but just get it welded and on the road as would be a real shame to chop it up
This is the ls left rear seat area right hand side is the same, other than these bits and left front inner arch that’s all that’s rotten structurally
Dan_NL
F-Pace (X761) / C-X17
Aug 19, 2020 07:12 AM
DougXK8
May 18, 2020 05:23 AM
peterv8
Jun 29, 2019 11:00 AM
FtypeRRR
Dec 19, 2017 02:54 PM
Nightsounds
May 30, 2015 03:44 AM
