soliciting suggestions WRT a rebuilt 3.4l engine
Old Apr 7, 2023 | 12:19 PM
hueyhoolihan's Avatar
Default soliciting suggestions WRT a rebuilt 3.4l engine
this monday i will be speaking to a Jaguar engine rebuild specialist shop and i would like to gather some suggestions as to what to ask the proprietor concerning a 3.4l engine that they have already rebuilt and is for the most part, ready to go. IOW i'm expecting to replace, entirely the short block in my current 3.4l engine, if not the head too. i'm very familiar with the rebuild process as regards engines from the era. so i can speak intelligently (my assessment!) to them, generally, about their rebuilt engine, i think. ...just fearful i will leave something out.
questions i should ask concerning the rebuilding a head would also be helpful, as i may decide to have that done too.
thanks in advance for any and all insights.
Old Apr 7, 2023 | 12:35 PM
JeffR1's Avatar
Ask if the water ports on the head where the coolant flows from the block into the head are not all corroded away at the edges.
Some times it is possible to add aluminum and cut the edges back to speck _ this requires the head to be re-surfaced of course.
If the ports are really bad, then the rest of the aluminum on the inside is just as corroded, failure can happen around the valve seats.
Are the valve seats still serviceable ? Machinists will cut them too much so you can't find shims thin enough to get the correct valve clearance.
When this happens some material has to be ground off the end of the valve stem to get enough clearance _ this is a very bad practice. (you may ask my why later if you want)
A bad machinist will "deck" the head with out straightening it first, while this may seem OK, it still leaves the rest of the head warped.
This causes the camshaft to bind on its bore, and the cam covers not fitting properly _ the cam covers will always seep oil as no amount of tightening will correct this.
Are the lifter buckets lose, this is common if the car has been over heated badly ?
Lose valve guides and wear on them ?
All heads have to be pressure tested, even if the car wasn't using water, it's just a given.
There should be a work order as to what has been done, and everything should be documented.
Old Apr 7, 2023 | 12:57 PM
thanks! i will ask them.
Old Apr 7, 2023 | 03:12 PM
Peter3442's Avatar
Have the sludge trap plugs been removed from the crankshaft and the sludge and solidified muck thoroughly flushed from the traps and oilways? To be sure he's actually done it, ask him how he removed the plugs. They are staked in place and total b...s to extract.
You need to read up on body language and look the rebuilder in the eye in the discussion. The fact is that if he's good, he's probably done everything well; and if he's not, he'll most likely respond yes to all the questions anyway.
Apologies for my total lack of faith in human nature.
Old Apr 7, 2023 | 03:48 PM
Originally Posted by Peter3442
...Apologies for my total lack of faith in human nature.
apologies unnecessary, ...i've found that it's an unfortunate "occupational hazard" of the aging process.
Old Apr 7, 2023 | 08:21 PM
Glyn M Ruck's Avatar
Ensure the bores are correct for size, taper & ovality for your oversize pistons. I don't know what oversize you are boring to as the 3.4 can go up to 60 thou being un-sleeved. The 3.8 only 30 thou. though & you re-sleeve. The 3.8 has Brivadium sleeves.
Old Apr 7, 2023 | 08:45 PM
yes, good idea, i hadn't thought of that. i'll ask.
Old Apr 8, 2023 | 01:13 AM
Refresh page for edit.
Old Apr 8, 2023 | 02:57 AM
Peter3442's Avatar
There's a current thread that started with the crankshaft rear oil seal. Everything point in that is relevant from the seal to skimming the deck of the block with the (new) timing cover in place.
Old Apr 8, 2023 | 04:24 PM
primaz's Avatar
For performance and reliability, some of the key things I have had done on different heads for engines of many brands are: upgrade the intake/exhaust valves to larger sizes for performance, or at least upgrade to a more modern materials for valve seats (nickel/bronze, etc.) to run on newer fuels, and do either 3-angle, 4 angle, or full radius on the valves for better flow. For more power consider having the heat ported so that it provides smoother and better flow. For reliability look at better quality components (rockers, springs, valves, guides, etc.)
For the bottom end even for more stock/street for reliability as well as power see what the cost difference is if the engine was balanced and blue-printed where they take more care in the machining process, etc. Also look at better quality forged internals such as pistons, crank, and overall better quality parts, bearings, rings, etc. Any rebuild is a big expense and time for the job so try to stretch your budget on the internal quality of the parts and how it is rebuilt so it will last longer.
Old Apr 8, 2023 | 06:52 PM
thank you for your assistance. i'll surely be asking about balancing. when i rebuilt my mga engine many years ago, having the crank, rods, pistons flywheel and clutch balanced made a world of difference. most noticeably, was how quickly the engine would rev.
Old Apr 8, 2023 | 10:53 PM
JeffR1's Avatar
What reputable machinist wouldn't balance an engine, isn't that a given, especially a long stroke engine from a Jag ?
Old Apr 9, 2023 | 02:09 AM
Absolutely Jeff. My crank, flywheel & clutch assembly was way out of balance before we corrected.
Old Apr 9, 2023 | 03:45 AM
Peter3442's Avatar
The crank should be balanced by itself first, then the other parts. Which connecting rods to use? Many upgrade to the later series 3 XJ rods as they are stronger. But they are also I believe heavier. I'd stick with the early Le Mans winning rods with all their oilways unless I had the odd 2000 spondulix to splash on a set of lightweight H section.
Old Apr 9, 2023 | 05:27 AM
My rods & pistons were weight matched.
We balanced crank & flywheel separately and then as a unit including clutch.
While videos of the plant balancing crankshafts looks impressive they did not do a very good job of it in reality. We re-balanced every crankshaft they sent to SA on top, new equipment for the era.
Old Apr 11, 2023 | 08:51 PM
just got back from builder in idaho. they've worked up an estimate on rebuilt block and head using a contemporary block and its matching head from roughly the same time. ...same displacement too, 3.4l.
see new thread "...does this look reasonable..." for details.
Charles J. Edward
34
Jun 10, 2024 09:13 AM
sgaunce
Dec 19, 2020 08:11 AM
hstovall1
Dec 13, 2017 03:35 PM
MalnFaye
Jun 10, 2016 04:15 PM
rfarmery
Nov 19, 2015 01:53 PM
