"Special Equipment" specs for Mark 1's
Old Nov 25, 2025 | 09:11 PM
geodon's Avatar
Default "Special Equipment" specs for Mark 1's
Did SE versions of the Mark 1 have 9:1 compression ratio cylinder heads?
I know about the disc brakes & wire wheels.
What other enhancements were offered?
Edit: OK. They got the 9:1 via domed pistons not by changes to the head. My bad.
Old Nov 26, 2025 | 08:40 AM
Coventry Foundation's Avatar
Jaguar issued a tuning manual (E/112)
for 2.4L cars. Not sure if you have a 3.4 or 2.4 but the manual goes through 3 stages of tune. Standard BHP was 112@5750 RPM. Stage 1 was 119 BHP @5800 RPM. Stage 2 was 131@ 5900 and Stage 3 was 150 @6000. In none of these do they offer 9 to 1 pistons. Hope this helps.
Last edited by Coventry Foundation; Nov 26, 2025 at 10:32 AM. Reason: additional info
Old Nov 26, 2025 | 11:19 AM
Peter3442's Avatar
CF has given the tuning info, which may well be what you want. However, the 'Special Equipment' option on the 2.4 consisted of a heater, tachometer, cigar lighter, back seat centre arm rest, screen washers, fog lamps, rear interior lights, enamel on the exhaust manifolds, leaper on the bonnet. I don't recall ever seeing a 2.4 without these.
Old Nov 26, 2025 | 11:24 AM
geodon's Avatar
Thanks guys!
I should have been more explicit.
Did the factory issued 3.4 litre "Special Equipment" cars have 9:1 pistons?
Thanks again
Old Nov 26, 2025 | 11:45 AM
Peter3442's Avatar
I don't think the 3.4 came as 'Standard' or 'Special Equipment' versions, unlike the 2.4. In fact, the SE features on the 2.4 were all standard on the 3.4. Still, there were options and 9:1 (and 7:1) pistons were amongst them for the 3.4 engine.
PS The ZB Magnette sounds like something special!
Old Nov 26, 2025 | 12:08 PM
geodon's Avatar
Re: the Magnette,
Peter, it's even better than as described. I forgot to include in the text that I also fitted a Moss Motors Eaton supercharger! (FIXED!)
Whilst I do have a 3.9 banjo diff on the shelf I kept the original 4.55 unit because I used the Ford Type 9 gearbox from a European Sierra that had the optional low ratio 1st gear and I was interested in acceleration rather than long legs.
I swear to God when I get into 5th gear it feels just like a Jag!
Pre war, MG made delightful sporting saloons eg the VA etc. Post war we got the MGY & then the Magnette- hardly soul-stirring drives.
MWC
Jun 12, 2024 01:12 PM
my420
17
Oct 17, 2023 08:16 AM
stasha
XK120 XK140 XK150
Nov 27, 2022 02:06 PM
1950Jag
Mark V - X 420G
Nov 17, 2022 07:44 AM
andyw
Aug 15, 2016 12:15 AM
