Torque setting
Old Jul 3, 2015 | 01:53 PM
kactaf's Avatar
Default Torque setting
Hi Team
Could anyone tell me what the torque figures should be for fitting the sump on a MK2 . It's an alloy sump so don't want to crack it.
K
Old Jul 3, 2015 | 09:59 PM
redtriangle's Avatar
Damned if I can find that setting, sure I've see it somewhere!
The XJ6 manual has a comprehensive list of torque settings (pp. 06-1 to 06-4) but nothing on the engine sump. I would offer to suggest 10-13 lb/ft which is what they quote for the auto transmission oil pan which I think is also alloy. I think the order of tightening is important, i.e. work from the centre bolts towards the ends, same method as the cylinder head. Cheers & beers
Old Jul 4, 2015 | 06:18 AM
Jose's Avatar
I agree with Peter, there is no specific torque setting for the 26 bolts of the oil sump in the 3.4 and 3.8 engines, regardless of the model car. A 3.4 and a 3.8 are the same engine whether on a MK-9, S type, or MK-2.
there is however, a short bolt which goes only on the front left-side of the sump if you are standing in front of the car.
Old Jul 5, 2015 | 01:25 PM
Jagfixer's Avatar
I just spent time looking thru manuals from 1948-1992 for sump torques. None. Make sure pan and sump have smooth surfaces, good gasket and sealer, tighten until gasket/sealer starts to expand. Check regularly for seepage and retighten on maintenance schedules.
aholbro1
Dec 29, 2024 06:46 PM
mrplow58
Jan 21, 2024 05:53 AM
Neil1664
Jan 20, 2022 08:59 PM
duecedriver
Dec 25, 2015 11:47 AM
chatmanx
Sep 11, 2015 07:17 PM
