What lubricant can I use for power assisted steering?
Old 05-04-2017, 11:01 AM
DavidEC's Avatar
Default What lubricant can I use for power assisted steering?
I have a 1967 S Type Jaguar with power assisted steering - what commercially available lubricant should I use in the oil reservoir?
David C
Old 05-04-2017, 11:40 AM
Jose's Avatar
Received 2,440 Likes on 1,835 Posts
you mean in the power steering FLUID reservoir?
Power Steering Fluid. You can also use Transmission fluid. Type F or equivalent.
join the International Jaguar S type Register Forum where you can download a Maintenance Chart for these rare Jags. Click on the link below.
Jaguar 'S'-type Register
DavidEC (05-04-2017)
Old 05-04-2017, 02:05 PM
gene61jag's Avatar
I use ATF, Type F or Type FA also.
Old 05-04-2017, 04:03 PM
DavidEC's Avatar
Thanks both - the original service manual calls it an oil reservoir, but I guess it is the same thing, i.e. item 6 on the service chart.
Old 05-04-2017, 06:30 PM
Jose's Avatar
it is basically the same thing but if you go buy it, some autoparts stores make a distinction between oil (for engine) and fluid (for transmission / power steering).
maybe because transmission fluid and power steering fluid are Red synthetic and oil is golden mineral?
also, ATF means: Automatic Transmission Fluid.
Old 05-05-2017, 09:19 PM
primaz's Avatar
I use Redline Power steering fluid as the standard types had issues due to heat and the Redline works with no issues
LnrB
12-07-2022 07:51 PM
Don B
General Tech Help
11-09-2015 12:59 PM
Kevin D
05-07-2010 10:49 AM
adreasx
01-25-2009 08:40 AM
Quick Reply: What lubricant can I use for power assisted steering?
