1001 xjs a/c
Hi folks,
I have been members of several jag lovers lists in the past;saloons XK and E-Types.
Now I have an XJS with an a/c problem. the blower motor runs constantly. I suspect there is a relay that is stuck, but I have no idea where it is, My experience with stuck relays is if you tap on it, it will unstick. Any ideas where the relay(s) might be and am I on the right track. Many thanks in advance.
Frank Morse Tamp[a, FL
The relay could be stuck, or the Darlington transistor failed, or maybe both. Both items are located inside the blower motor assembly itself. Removal of the blower assemblies isn't exactly a pleasure cruise....but it's doable, obviously
The link below offers good info and pics
Air conditioning blower control
Welcome to the Forums.
The members in the XJS Tech Section will add to what Doug has already suggested.
Might pay add your vehicle details to your Sig, then we all know the beast involves, and give better assistance.
Good luck.
Good luck.
Welcome to the forums Frank,
Follow this link https://www.jaguarforums.com/forum/xjs-x27-32/ to the XJS forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the US Lower Atlantic Region forum by following this link https://www.jaguarforums.com/forum/u...r-atlantic-66/ to find other members in your region.
Enjoy the forums.
Enjoy the forums.
Welcome to Jaguar Forums Frank,
Are there two separate a/c blowers? If so, it would seem to me that my problem is something that is common to both blowers. I am getting equal air flow from all vents. Can someone who has had the same problem talk to me or is that against the forum rules?
Frank Morse
Frank Morse
Yes, two blowers...but each with its own relay and circuit board (assuming you have the Mk III system)
If both blowers remain on at all times then an upstream control problem is plausible. If only one, then it's probably down to the circuit board for that individual blower.
As a fellow newbie, welcome! I can support Doug's comments. I had the same problem with my Daimler Double Six which has the same Delanair a/c. It was a long time ago and we had several other problems in the car to fix, so I don't remember exactly what we did to make the repair. I think that it was a transistor. I recall one thing that served as a short term way of avoiding a flat bettery when the blower continues running after you've turned the ignition off. With the blower turned to off, turn the ignition on again (without starting the engine) and then off and, with a bit of luck, the blower stops running.
If you'd tell us what year your XJS is and/or if it has the Mk II or Mk III Climate control it would help
Also is there a jag-lovers list for XJSs like with saloons, etc?
Frank,
READ THIS CAREFULLY
1. I have already asked you to add vehicle details - twice and even offered to do this for you. The reason for this is the XJS had many different specifications over 21 years of production.
2. this is the Intro forum. It is NOT the place for lengthy technical troubleshooting posts. The XJS forum is the place to pursue your issue.
3. all members have the appropriate anonymity essential on a public forum. Asking for email addresses is not acceptable and posting your own is not advisable.
I've removed your post asking Doug for his email address and removed another giving your email address. We have a PM (Personal Message) feature for individual and private contact. However, discussing problems, repairs and solutions in secret rather negates the entire point of having a forum.
I'm CLOSING this thread. If you wish to continue discussion of your A/C issue, start a new thread in XJS ( https://www.jaguarforums.com/forum/xjs-x27-32/ ) forum and add your vehicle details.
READ THIS CAREFULLY
matjohns
Oct 13, 2011 03:01 AM
