1990 jag steam out of right fender well
Welcome to the forum macdoesit,
To modify a post, click on the black edit button from the group at the bottom right of the post you want to edit.
be very careful to avoid overheating the V12. Follow this link XJS - Jaguar Forums - Jaguar Enthusiasts Forum to the XJS section for help, advice and information.
Remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
You can also visit the US Southwest Region section by following this link https://www.jaguarforums.com/forum/southwest-us-az-tx-nm-ok-37/ to find other members in your region.
macdoesit (12-09-2012)
Received 6,275 Likes
Never trust a Jaguar temperature gauge. They haven't made one yet that's accurate.
Received 9,006 Likes
welcome aboard ....... good to have you here with us here at Jaguarforums.
How do you know motor temp?
Last edited by macdoesit; 12-09-2012 at 02:10 PM. Reason: says I need more characters.
Get used to the position for "normal" on the gauge and if it begins to climb, stop and investigate without delay. Moving over to reading hot means it's already seriously overheated. On nearly all my 70's and 80's Jaguars, straight sixes and V12, the normal position was about a quarter of the way across the gauge. It would take bursting a cooling hose to move it to hot!
Their temperature gauges got even worse in the late nineties - deliberately set to read normal unless practically boiling. Many a V8 owner has had a ruined engine because of this.
VinnyT
69
05-17-2021 09:30 AM
