1995 Jaguar Vanden Plas
Old Apr 8, 2011 | 06:21 PM
darkmon316's Avatar
Default 1995 Jaguar Vanden Plas
About two months agao, I was driving along the highway at 60 miles an hour and the engine suddenly shut down without any cautions or lights on the dash. After I got it back to my house, I had a mechanic look at it and he found out that the lower timing chain had broken. Actually, he was not sure if the lower timing chain had broken or if the left hand upper timing chain damper had broken, logged itself in the lower timing chain, and caused the lower timing chain to break. He is not sure what kind of damage the engin has as of yet. I bought an upper and lower timing chain. The upper timing chain came with a master link, but the lower timing chain did not. He wants to install both chains to be able to do a compression test and see if the valves are an issues with the head. He does have it in timing. The upper chain was no problem to install since it had a master link, but since the lower timing chain has no master link he is not able to install the chain without the proper tool to take it apart. Any help with installing the lower timing chain will be very much appreciated. Then at least we can move on to see if we have compression in the cylinders.
Old Apr 9, 2011 | 08:14 AM
Welcome to the forum,
If you go to the XJ tech section you will find lot's of info on timing chain changes.
Old Apr 9, 2011 | 02:41 PM
darkmon316's Avatar
Default 1995 Jaguar Vanden Plas Timing chain
I forgot to list the type of engine in my last post. It is a six cylinder, 4.0 L. I have looked in the forum and only found instructions for an 8 cylinder, and not a six. I am new to this forum, if the information is available, please direct me in the right direction. Thanks in advance.
Kevin
Old Apr 10, 2011 | 07:31 AM
Gus's Avatar
Gus
Hello and welcome to jaguarforums.com. I know that you are anxious to get started and we are anxious to meet you and talk about your car. We have a baseline / criteria that must be met before full access can be granted. Please enjoy the forum and be patient once the baseline has been satisfied full access will be granted. Please continue to post and accept my welcome to the forum.
Old May 17, 2011 | 08:45 PM
darkmon316's Avatar
Thank you for the information. A little bit more update on my jaguar. I found out that the 4.0L engine has three chains on it and not just two: One for the camshafts to the idler, one from the crankshaft to idler to turn the camshafts, and one from the oil pump to the crankshaft. I finally got all of the chains on and the camshaft position sensor in position. It will start, but with the assistance of a bit of accelerator to keep it going. It runs very rough. I did a compression check, and I only have compression on the numbers 2, 4, and 6 cylinders (150 psi or better). I have NO compression on the numbers 1, 3, and 5 cylinders. As I said before in my first posting, I was going down the road at 65 MPH and the engine just shut off. After taking the engine apart, I found out a bolt came loose from one of the upper chain guards and ended up breaking the primary timing chain. Any help will be appreciated.
Kevin
1995 Vanden Plas X300
4.0 L Engine, 176,500 miles
Old May 18, 2011 | 07:23 AM
tcarby's Avatar
Welcome to the forum. I also have a 95 SJ6 VDP 4.0 L. I have 99k miles on mine. Just to be curious, how many miles do you have on your jag? Mine seems to be running fine.
Terry
Old May 18, 2011 | 12:41 PM
RCSign's Avatar
Welcome Kevin
Hope the guys in the XJ Section can help you out Happy Motoring
Old May 18, 2011 | 07:55 PM
welcome to the forum Kevin, good to have you here.
Sorry to hear about your issues, but you need to post them into the relevant section if you hope to get the answers you need
You might find the off topic good for fun, maybe check out the mug shot thread and add yours?
Some really good guys and great techs, top vendors offering good pricing levels and great service, and more to come....all good
In the meantime I've upgraded you manually to full forum access so you can better view the site
paulyling
Mark V - X 420G
Aug 15, 2023 09:33 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
thedugger1
Sep 24, 2015 05:32 PM
Sprayall
Sep 3, 2015 07:49 PM
Newsguy
Aug 30, 2015 11:27 AM
