Bad Start
Old Sep 4, 2013 | 11:20 PM
lelamitie's Avatar
Default Bad Start
Hi Jim and all
I just purchased my first Jaguar on 7.23.13,a 02,S type,6cyl,4 dr.,with 92082 mi. from
a well known Nisson dealer.
On the way home in my treasure, I noticed the check engine light was on and the next morning, I had to call AAA to start it .
The dealer put in a new battery, but the light stayed on and after three scans[codes p0420 and p0430]Ba,
the diagnosis was two plugged cat converters.The dealer said to ignore it.
Next, I took a two hour trip and it slowed to a crawl in heavy traffic and almost stopped. A light came on announcing a gearbox fault. I can't set the clock, one of the windshield washers does not work, and as I drove it to mail my first payment, one of the main headlights went out
I'm getting a bad start in the Jaguar world! Help! Please advise on what to do and what it needs. I am broke as a dog from buying it.
Cheers!
Old Sep 5, 2013 | 02:15 AM
Welcome to the forum lelamitie,
Good to have you here with us at Jaguar forums. You're not getting the best introduction to Jaguar ownership. The P0420 and P0430 codes is usually an issue with HO2 sensors.
Follow this link S-Type / S type R Supercharged V8 - Jaguar Forums - Jaguar Enthusiasts Forum to the S-Type section for help, advice and information.
You can also visit the US Southern MidWest Region section by following this link https://www.jaguarforums.com/forum/southern-midwest-ar-la-ms-ky-tn-al-67/
Old Sep 5, 2013 | 02:59 AM
scotty1511's Avatar
Welcome aboard.... Unlucky with the start...fingers crossed all goes well.
Old Sep 5, 2013 | 05:50 AM
Old Sep 5, 2013 | 06:11 AM
welcome to the forum and the Jag family. Sorry to hear the adventure has had a rocky start but following the links Graham provided will guide you back to an enjoyable ownership experience. You will find a wealth of info and support here - best tool in a Jag owner's tool box.
Hope the issues get sorted quickly so you can enjoy the drive.
Old Sep 5, 2013 | 06:30 AM
Cambo's Avatar
Welcome to the forum!
As Graham said, those codes point to HO2 (Hot O2) sensors, not so much to blocked cats.
The workshop manual says for P0420 & P0430;
HO2 Sensor disconnected
HO2 Sensor to ECM wiring fault
HO2 Sensor heater to ECM wiring fault
HO2 Sensor heater failure
Upstream HO2 Sensor failure
Downstream HO2 Sensor failure
Catalyst failure
In that order, so blocked cats is the least likely issue. HO2 sensors are relatively cheap, new cats are not.
Both codes means the fault lies on both banks of the engine, pretty unusual, get a mechanic to check the HO2 sensors and the wiring.
Gearbox Fault message should also have left a code. Depending on that code it could be anything from a failing battery (yes, seriously) to something like the wiring plug on the side of the gearbox coming loose. Don't assume the worst.
Windscreen washer probably just needs a sewing pin pushed down the jets to clear them out.
And the headlight...well even Rolls Royce's have been know to blow a headlight bulb when they get to be 13 years old...
Good luck!
Old Sep 5, 2013 | 08:45 PM
Hey there and welcome aboard....... good to have you here with us here at Jaguarforums
If you need any further help with the site, please just ask any moderator, veteran member and we'll be glad to assist.
In the meantime, any useful site information you may need such as how to post pictures, edit signatures, add videos, using the search
facility etc, can be found here within the following link
Helpful_information
See you in the forums....
Wolfy
May 28, 2024 08:06 AM
JarodL
Mar 7, 2024 01:39 AM
PMKimpton
Aug 3, 2019 08:22 PM
Bones
Sep 8, 2015 08:34 PM
alpecsa
Sep 7, 2015 11:55 AM
