Changing the time
Old Mar 10, 2013 | 01:24 PM
tesneath's Avatar
Default Changing the time
I've tried everything to change the time on my 2008 X-type and cannot do it. I have the owners manual and still no luck. Please help me Im getting very frustrated with this. My car does not have a touch screen.
Old Mar 10, 2013 | 01:48 PM
Welcome to the forum tesneath,
If you need any help or advice check out the tech section X-Type - Jaguar Forums - Jaguar Enthusiasts Forum please take a look in the regional section also Lower Atlantic - NC SC FL GA - Jaguar Forums - Jaguar Enthusiasts Forum
Take a look at this for the clock setting.
File Type: pdf
Old Mar 10, 2013 | 03:38 PM
Looking at the button sequence to change the time on the X-Type, it's nothing anyone is likely to hit on by accident!
When you've got the clock set, follow Norri's link to the X-Type section for help, advice and information. The 'HOW TO' thread at the top there is a good place to start for info on regular issues.
Old Mar 10, 2013 | 05:45 PM
Muddydog's Avatar
Welcome to the forum, tesneath!
Old Mar 11, 2013 | 08:34 AM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Steve
Old Mar 11, 2013 | 07:51 PM
tesneath's Avatar
Clock adjustment Non-touch screen
1. Repeatedly press and release the MODE button (on the audio unit) until ADV MODE N/Y is displayed.
2. Rotate the volume control to select ADV MODE YES and then press MODE.
PM TP ST
3. CLOCK SET will be displayed with the 12/24 hours indicator flashing. Rotate the volume control clockwise for 24-hour display; counterclockwise for 12-hour display.
4. Press MODE to select the hour setting. Rotate the volume control clockwise or counterclockwise to adjust the setting.
5. Press MODE to select the minutes setting. Rotate the volume control clockwise or counterclockwise to adjust the setting.
6. To exit press and hold MODE or wait approximately five seconds until the display reverts to audio mode.
I finally got it maybe this can help someone else with the same problem I had....
Old Mar 12, 2013 | 12:40 PM
What could be more straight forward? LOL
Welcome to the forum.
Just wait until you need to reprogram the alarm.
Old Mar 20, 2013 | 10:41 PM
Hey there and welcome aboard....... good to have you here with us here at Jaguarforums
Any useful site information you may need such as how to post pictures, edit signatures, add videos,
use the search facility etc, can be found here within the following link Helpful_information
Shawn Svacha
Nov 4, 2019 02:47 PM
tberg
Sep 7, 2015 07:32 AM
Sprayall
Sep 3, 2015 07:49 PM
dcvickers
Sep 2, 2015 06:14 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
