Coolant leak and cylinder misfire.
Old Nov 29, 2018 | 05:49 PM
Kyle Considine's Avatar
Default Coolant leak and cylinder misfire.
Ok so i had multiple cylinder misfires. Replaced upper and lower intake manifold gaskets. Problem solved for several months. Had a coolant leak from thermostat and then water outlet housing or so i thought.by the way this is an 03 xtype 2.5. Replaced both thermostat and housing with brand new parts. (Not leaking). Then realized water pump leaking. Going to replace this weekend. Now showing cylinder 5 misfire again. Could this be fluid on the spark plug cousing this??? If so how do i fix? Running like crap ever since i noticed water pump leaking. Any help would be great!!
Old Nov 29, 2018 | 05:55 PM
Welcome
The X Type Tech Section will know the answers.
Most common is oil in the spark plug wells from the cam cover gasket/s.
Good luck.
Old Nov 29, 2018 | 05:57 PM
Maybe coolant in the spark plug wells?
Old Nov 29, 2018 | 06:59 PM
Welcome to the forum Kyle,
I can see you've already found your way to the X-Type forum with this issue so there's no need for a link to it from me. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the US Northeast Region forum by following this link
https://www.jaguarforums.com/forum/us-northeast-35/ to find other members in your region.
Enjoy the forums.
Old Nov 29, 2018 | 07:11 PM
Daf11e's Avatar
Welcome aboard Kyle.
Old Nov 29, 2018 | 08:59 PM
Hello, Kyle,
Old Nov 30, 2018 | 04:51 AM
o1xjr's Avatar
Welcome to the forums.
Old Nov 30, 2018 | 05:41 AM
Welcome to Jaguar Forums Kyle,
Old Nov 30, 2018 | 06:56 AM
extheaterkid
Oct 3, 2018 07:15 AM
Gblauf
Mar 3, 2013 09:36 AM
Dirkman
Aug 30, 2012 06:53 PM
JagScott
Aug 14, 2010 04:08 PM
