Cooling System Bleeding
Old Nov 6, 2019 | 06:22 PM
miami jags's Avatar
Default Cooling System Bleeding
Hi Everyone,
First I want to express my appreciation for this extremely valuable resource. It has helped me through 3 X350's. My most recent is a 2005 Vanden Plas, now with 169,000 miles. Yesterday I had the pleasure of replacing the valley hose and have now run into a problem bleeding the system. Adding coolant as the car is warming up using the normal fill level results in the level suddenly rising as the car warms up and then overflowing the tank. Letting the car sit after shutting it off results in the coolant draining out of the tank until it is empty. I have not driven the car since changing the valley hose and the foregoing occurred idling in my garage.
Many thanks in advance for your insights
Bill
Old Nov 6, 2019 | 07:31 PM
Welcome to teh Forums.
The X350 members will know, I have not had an X350, yet.
Good luck.
Old Nov 6, 2019 | 08:26 PM
Hello, Bill,
I had a car do that once, and it was because when the thermostat opened it allowed a bubble that was hiding in the back of the block to escape and burp out a bunch of coolant. If I added coolant while the car was running and warm I could fill it. However, it was NOT a Jaguar so you might not want to try it with your car.
Old Nov 6, 2019 | 11:12 PM
Daf11e's Avatar
Welcome aboard Bill.
Old Nov 7, 2019 | 03:18 AM
o1xjr's Avatar
Welcome to the forums.
Old Nov 7, 2019 | 03:44 AM
Welcome to the forums Bill,
I wouldn't use that fill technique on a Jaguar. The X350 Workshop manual specifically cautions against running the engine with the pressure cap off when doing a coolant refill.
It sounds like you are already familiar with the relevant model forum but if not, follow this link https://www.jaguarforums.com/forum/x...-x350-x358-28/ to the X350 forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also use the US Lower Atlantic Region forum by following this link https://www.jaguarforums.com/forum/u...r-atlantic-66/ to find other members in your region.
Enjoy the forums.
Old Nov 7, 2019 | 05:40 AM
Welcome to Jaguar Forums Bill,
Old Nov 7, 2019 | 06:28 AM
M003thomas
Sep 28, 2017 06:03 PM
Flyypaul
Jun 14, 2015 05:12 PM
blaydes99
Jul 7, 2014 10:41 AM
JaggyZ639
Dec 19, 2013 08:26 AM
robr
Jan 31, 2010 01:44 PM
