Dano from Oregon
Old Nov 4, 2015 | 11:52 AM
danomite's Avatar
Default Dano from Oregon
Dano here from Oregon, USA,
I live in beautiful Oregon. My family has owned Jags through three generations. My grandfather was the head Jag mechanic at Hanham Motors, unfortunately both granddad and Hanham Motors are both gone now. I'm the owner of a 1994 XJ6 4.0L. When I bought the car it was perfect nice inside and out, Everything worked great. It started to not start if you didn't move the gear shifter around a bit or not start at all. I was driving to work the other day and out of the blue it died, no indication at all it just turned off. I got it home that day and it did the same thing a couple of times and now it will not start at all. I get a Fuel Fail 69 VCM code. I have check the battery and it checked out okay, so next is the neutral switch(it may be helpful to know that it allow me to shift into any gear with or without the car on or off and without the brake on). When it runs it is the coolest car, everywhere I go people what to look at and talk about it. So running is better for me, it is my daily driver.
Old Nov 4, 2015 | 02:59 PM
o1xjr's Avatar
Welcome to the forum
Old Nov 4, 2015 | 05:37 PM
Welcome to the forum Dano,
Follow this link https://www.jaguarforums.com/forum/xj40-xj81-25/ to the XJ40 forum for help, advice and information.
You can also visit the USA Western Region forum by following this link https://www.jaguarforums.com/forum/usa-western-ak-ca-nv-ut-hi-wa-id-38/
Enjoy the forums.
Old Nov 4, 2015 | 05:59 PM
Old Nov 4, 2015 | 06:46 PM
Hello, Dano,
It's the Pits when your Driver quits!
Having to wiggle the shifter around to make it start sounds a bit like the Neutral Start circuit has a problem.
Someone will be along shortly to direct you to the correct section where you can get help for that.
Old Nov 4, 2015 | 06:52 PM
Welcome.
THat linear switch definately needs some TLC.
Then:
Fuel pump, and/or fuel pump relay (common issue with the XJ40)
Crank angle sensor, not so coomon.
HT coil lead, FROM the coil TO the distributor cap is an XJ40 thing.
The group in the '40 section will add to that very quickly.
Old Nov 4, 2015 | 07:16 PM
Daf11e's Avatar
Welcome aboard Dano.
Old Nov 5, 2015 | 05:44 AM
Welcome to Jaguar Forums Dano,
Old Nov 5, 2015 | 02:02 PM
danomite's Avatar
Thanks everyone,
Thanks for all the nice greetings and advice. Happy to be here as well.
Dano
Old Nov 13, 2015 | 11:03 AM
Using JF "How To"
luds1
Oct 20, 2015 09:53 AM
Shabo
Oct 18, 2015 11:17 PM
hstovall1
Oct 17, 2015 09:32 AM
Shelby676
XJ40 ( XJ81 )
Oct 11, 2015 10:32 PM
